Thread started 19 May 2011 (Thursday) 19:59
I need help setting up on camera YN rf-602 & flash
tolyD
May 19, 2011 19:59 |  #1
Next month I'll be shooting wedding for a friend and im trying to figure some things out using speedlites. And of course I ran in to some problems with YN rf triggering. I want to have one speedlite attached to the camera in the hot shoe for fill and be able to trigger the other flash using the RF trigger. whats the best way to set this up?? i have tried with pc cable and im noticing decreased sync speed, lose cable and no way to attach the trigger anywhere. now im thinking maybe YN triggers is not such a good idea for this. any advise/hints on this? thanks guys in advance:cool:
5D MkII | 35L | 50 1.4 | 85 1.8 | 2x 580ex II |
flick (external link)r
web (external link)
facebook (external link)
canonguy14
Joined May 2011
May 19, 2011 20:10 |  #2
Pocketwizard MiniTT1 transmitter. The pocketwizard slides onto the hot shoe of your camera and then your on-camera flash on top of that.
http://www.bhphotovide​o.com …io_Slave_Transm​itter.html (external link)
Add a Pocketwizard Plus 2 to the off camera flash.
http://www.bhphotovide​o.com …II_Transceiver_​Radio.html (external link)
Canon 5D MkII x 2 | Canon 35mm f/1.4L | Sigma 85mm f/1.4 | Canon 100mm f/2.8L Macro | Canon 17-40mm f/4L | 600EX-RT x 2 | 580EXII | AB800
Alex J. Photography (external link)
Facebook (external link)
tolyD
May 19, 2011 20:14 |  #3
canonguy14 wrote in post #12443058 (external link)
ah man, now you are making me spend more money :p i was hopping i can do something with what i have.
web (external link)
canonguy14
Joined May 2011
May 19, 2011 20:22 |  #4
Just to be clear........have you tried setting your off camera flash as a slave and having the on camera(MASTER) fire it?
tolyD
May 19, 2011 20:28 |  #5
canonguy14 wrote in post #12443133 (external link)
This works good only in a small room. i want to be consistent with it and be able to trigger the second flash from the distance. Ill be using this outdoors as well.
web (external link)
huntersdad
May 19, 2011 20:48 as a reply to  @ tolyD's post |  #6
Unless the 602's can do something I'm not aware of, ain't gonna happen with them. I don't think they come with a cord you can plug into the on camera flash that can remote trigger the OCF via signal.
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
tolyD
May 19, 2011 20:59 |  #7
i had my own pc sync cord laying around. this is what i came up with but like i said, doing it this way the sync speed with the flash dropped to like 1/125 on my 5d mk2. this is too low for my use outdoors. i need max sync speed at 1/200 but this way using the pc cable i get black bar at 1/160 on every fifth shot i take and this forces me to drop my shutter to 1/125.
IMAGE: http://farm6.static.flickr.com/5062/5738181531_5fd8567c74_b.jpg
web (external link)
evilr00t
May 19, 2011 21:23 |  #8
tolyD wrote in post #12443338 (external link)
Does it sync at 1/200 if you keep the tx's button half pressed (green light lit)?
XTi, 1D3, 2x SB-28, 580EX, 550EX, Tamron 28-75, 50/1.8, "EF" 18-55 II, "EF" 18-55 IS, 85/1.8, 75-300 III USM, 70-200/4L
tolyD
May 19, 2011 21:30 |  #9
evilr00t wrote in post #12443478 (external link)
yep, TX pressed half way down triggers the green light on RX and this is normal. but it does this at no matter what shutter speed im using or even with camera on/off. is this what you are asking? im confused here...
web (external link)
evilr00t
May 19, 2011 22:59 as a reply to  @ tolyD's post |  #10
Okay, I have this crazy idea that perhaps the reason people are reporting slow sync speeds with the 602s is that the receiver has an inherent off->green/red delay.
So when mounted to the shoe:
Camera not busy: TX off, RX off
Half press shutter: TX green, RX off->green (slow)
Press shutter: TX red, RX green->red (instant)
Sync speed: 1/200
Not mounted to the shoe:
No trigger [camera idle or half press shutter]: TX off, RX off
Triggered [full press shutter]: TX red, RX off->red (slow)
Sync speed: 1/125
If you instead, press the TX button halfway, the RX should already be in receiving mode and it may sync at 1/200 instead of 1/125.
aRKay
May 19, 2011 23:18 |  #11
u might look the cactus v4 or v5.
http://www.gadgetinfin​ity.com/product.php?pr​oductid=17567 (external link)
1 on your camera ,then ur fill light
1 for the slave flash.
.....Stand By.......o.O
sakisf
Joined Apr 2011
May 20, 2011 00:10 |  #12
Or you can get a flash bracket and put the 580EXII on it (with a rf-602 receiver or sync) and the rf-602 tx on the hot shoe.
tolyD
May 20, 2011 09:40 |  #13
evilr00t wrote in post #12444007 (external link)
Sync speed: 1/200
Sync speed: 1/125
could be, ill do more testing once i get home tonight.
web (external link)
tolyD
May 20, 2011 09:42 |  #14
sakisf wrote in post #12444384 (external link)
but this will disable my ttl use incase i want to use it.
web (external link)
tolyD
May 20, 2011 09:46 |  #15
does hot shoe locks on this one so the flash stays secure?
aRKay wrote in post #12444131 (external link)
web (external link)
2,917 views & 0 likes for this thread, 6 members have posted to it.
1281 guests, 121 members online
