Thread started 21 May 2011 (Saturday) 02:50
Is it the weather or the 50L lens?
danielyamseng
May 21, 2011 02:50 |  #1
The weather at that time is quite clear. I can see the tower quite clearly without any fog. But what I don't understand is this is the best result I got by under and over it a few stops ( by changing the aperture). The shoot was taken using a 5D MK II 50mm f1.2 using f7.1 at 1/1000 AWB at noon.
The filter use for this lens is B+W UV filter. I've clean both the lens and camera beforehand. If it's the sensor/lens problem then in any condition I'd get a similar result. And I didnt' shoot at min aperture.
May I know what's the real cause of it?
IMAGE: http://farm3.static.flickr.com/2193/5742397094_7cdf0d4f8a_b.jpg
Sdiver2489
Joined Sep 2009
May 21, 2011 03:12 |  #2
Looks like the weather. You can always punch up contrast in post processing.
I didn't know anyone used the 50L at anything less than F1.2! (joking of course)
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
melcat
Joined Nov 2010
May 21, 2011 03:21 |  #3
Was it raining? Our visual systems are pretty good at editing that out, but cameras don't. The clue is that the top of the tower is worse.
phreeky
May 21, 2011 03:52 |  #4
If the above weather suggestions turn out to be false (though I think it's the weather most likely, too), then:
- Have you shot the same scene with another lens to rule that out?
- Is the lens fogging up due to going from indoor->outdoor or vise versa
- Did you try shooting it with the filter removed?
danielyamseng
May 21, 2011 04:20 |  #5
melcat wrote in post #12451166 (external link)
No it's not. But it's not a bright day either.Probably a bit cloudly. Oh gee, I don't even know of eyes are that smart, a lot smarter than the moderm DSLR :-).
phreeky wrote in post #12451214 (external link)
Never thought of that. But anyway, That's my widest lens at that time. Thus don't even bother to switch to 135L.
No. It's quite clear if I shoot a nearly/smaller subject i.e nearby building.
Oh, I never did that also. But I recall I've checked the filter and the lens it doesn't show any sign of fogging.
Would a ND filter would help in this case( In my opinion probably no)?
philwillmedia
May 21, 2011 04:36 |  #6
I'd say it's due to the atmospherics.
It doesn't look like a great day - fairly overcast would be my guess (edit - oops...you did mention that) and you were probably shooting back towards where the sun was hidden behind the clouds.
Is this straight out of the camera or have you processed? My guess it isn't processed.
I've had a play with it and a minor tweak to the contrast makes a big improvement.
If you want, I'll post it up for you to look at.
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
danielyamseng
May 21, 2011 07:34 |  #7
philwillmedia wrote in post #12451271 (external link)
Hmm, I think you're right.
I can't recall where's the sun, probably I can't see a clear sky.
Yes, It's indeed not undergo any processing except resize and watermark
Oh, that'd be great :-).
philwillmedia
May 21, 2011 07:50 |  #8
...If you want, I'll post it up for you to look at.
danielyamseng wrote in post #12451565 (external link)
...Oh, that'd be great .
As requested by the OP
Regards, Phil
danielyamseng
May 21, 2011 08:50 |  #9
Phil that's pretty fast :-) . That's looks much better, but still can't get good color saturation( partly due to the weather). Thanks, pal :-).
Let me guess, you just reduce the contrast level via photoshop and not using the Curve for adjustment. I think for this image either way the result is similar.
Thus can I concluded that the the time and weather is vital for a good quality image. Postprocessing won't help much if this two factor is not favorable to us.
Anyway, nowaday I'm too lazy to do post processing for landsacpe pictures, I would rather get it right from the camera, but looks like the weather condition is not really favorable to me.
Another thing is the top and bottom of the tower has different brightness. I guess adding a ND filter to even out the lighting doesn't help much either, is it?
philwillmedia
May 21, 2011 09:06 |  #10
no probs...
I just did a slight adjustment to the brightness/contrast and just gave the curves a minor tweak.
Because the building is grey and it was an overcast day, the lightng was flat and therefore what little colour you've got isn't going to look that great. Dull colours on dull day equals not good for colour saturation.
It may be worth giving a black and white conversion a try.
No matter how "right" you get it in camera, nearly every pic you take, whether it's jpeg or raw, will need some sort of processing.
With the uneven lighting top to bottom, I'm not sure if a ND filter would help.
Regards, Phil
Snydremark
my very own Lightrules moment
Gallery: 66 photos
May 21, 2011 09:19 |  #11
It looks like a combination of backlighting of the building against a bright sky and potentially some interference from the UV filter. Even high quality filters can cause some lack of contrast when angled against the light "just right".
2,304 views & 0 likes for this thread, 6 members have posted to it.
1464 guests, 131 members online
