Thread started 21 May 2011 (Saturday) 10:51
Missing info on top panel LCD
mikecox
Joined May 2011
May 21, 2011 10:51 |  #1
I am in Creative mode and the lower left corner of the LCD screen, on my 60D, is blank.
What conditions must be set for WB, Flash Exp and Mode to appear in that space on the LCD screen?
Is there a default menu setting that needs to be reset? I'm wondering if maybe, during my explorations, I changed the default and that's what prevents this information from displaying?
Michael :cool:
Canon 60D and 70D, Speedlite 430 EX II, PsCC, LrCC, and PrE 16
twixraider
Joined May 2011
May 21, 2011 13:30 |  #2
mikecox wrote in post #12452195 (external link)
What do you mean with lower left corner and which lcd sceen?
Super Rebel, | EF-S 17-55mm f/2.8 IS, | EF 70-200mm f/4 L IS, |EF 50mm f/1.8 II, |Canon 580EX II.
mhazlett
May 21, 2011 13:52 |  #3
Please post a picture of the LCD, and also, you have a typo in your sig haha :).
WEBSITE (external link)
Delija
May 21, 2011 14:54 |  #4
If you are referring to the "CA" ("creative auto") mode, which is my guess, since you said "I am in Creative mode" rather than "I am in ONE OF the creative modes"...then your camera is working as it should. I don't have a 60D, but I have a 7D which I would guess has the same "CA" mode - and that mode is an auto mode, so the info you are looking for can't show since the camera doesn't have that info - and won't until the instant you press the shutter button....(although you should see AWB on the top of the box for white balance - you just can't change it -nor can you change your metering from "evaluative" in "CA" mode).
Also, just so you know - the scale you refer to as "flash exposure" - AKA "flash compensation" (also not controllable in "CA" or "Green Box" mode) is only going to let you change your flash compensation when you press the corresponding button (but not in "CA" or "green box" mode). It will then revert to the center or wherever your exposure compensation is set. It only shows you the flash compensation when you set it or if you press the button to access it. As soon as you touch the shutter button it will show your exposure comp, not your FLASH compensation. It is just a shortcut to set your flash comp., not a source of constant info regarding that setting.
As for the top LCD showing what mode you are in - I have never seen that on any EOS camera...and it would make no sense to have it there. You would need to look at the top of the camera, so it is just easier to look at the dial on the left to see what mode you are in (or see the shooting info on the main LCD on the camera's rear by pressing the "info" button a couple of times (depending on how you have the "info" button set).
Hope this helps. If you truly are in a "creative mode" - and not in "CA", and that information is not showing, I would call Canon tech support and see if you have a real problem...(which I tend to doubt).
Best of luck,
D.
Wow, what a nice picture! You must have a really great camera!
mikecox
Joined May 2011
May 21, 2011 15:55 |  #5
mhazlett wrote in post #12452949 (external link)
Ok, I can make screen shots on my computer but how do I make a picture of the LCD on my camera? :confused:
Yes, thanks; took the opportunity to add to it while I was there.
Michael :cool:
apersson850
Obviously it's a good thing
Gallery: 35 photos
May 21, 2011 16:03 as a reply to  @ mikecox's post |  #6
Take a picture with your other camera.
You aren't trying to convince us gear geeks that you have only one, are you? ;)
But try Tv mode first. Things disappear in CA mode and then further south of that.
Anders
mikecox
Joined May 2011
May 21, 2011 16:04 |  #7
twixraider wrote in post #12452849 (external link)
Hmmm, both LCD screens have four corners... I've ID'd only one, how can I be more specific  :p
Sorry, the LCD Panel. As far as I can tell, it's the only LCD that displays this information in that location.
Michael :cool:
mikecox
Joined May 2011
May 21, 2011 16:40 |  #8
Delija wrote in post #12453199 (external link)
Sorry, I actually did mean ONE of the creative modes; as apposed to one of the automatic modes :oops:
As for the top LCD
Which I realize now is ID'd as the LCD Panel
as apposed to the LCD Monitor.
Sounds logical to me but check out the attached image.
In David Busch's book EOS 60D Guide to Digital Photography he states that this information should display in the area shown in the attached image. He doesn't, specifically say, when this information would display; as in what mode, but he says it does display and the attached image shows that information displaying in the "lower left corner".
Maybe I am going to have to do that, but I thought I'd be able to avoid that by checking here first.
Best of luck,
Thank-you and for the time you've taken to help me sort this out.
Michael :cool:
apersson850
Gallery: 35 photos
May 21, 2011 16:43 as a reply to  @ mikecox's post |  #9
Aha, now I understand. For these icons to show up you must set their corresponding values to something else than zero.
B/W shows only when using the Monochrome picture style.
The flash +/- only when flash exposure compensation has been set different from zero.
And WB +/- means that you have set white balance compensation for at least one color pair.
Anders
mikecox
Joined May 2011
May 21, 2011 16:47 |  #10
apersson850 wrote in post #12453424 (external link)
:lol: Actually I gave my Canon PowerShot to a friend, and I actually do have only one ;) But I realized that I have a manual; the book I referred to is digital so I can't scan it. But I did scan the Panel in the manual and attached it to one of the posts in this thread.
Actually I've cycled through all the modes and that information doesn't display in any of them. :eek:
Michael :cool:
apersson850
Gallery: 35 photos
May 21, 2011 16:49 as a reply to  @ mikecox's post |  #11
No, but you did read my reply above now, did you? It doesn't display because you haven't set anything.
Anders
mikecox
Joined May 2011
May 21, 2011 17:00 |  #12
apersson850 wrote in post #12453552 (external link)
BINGO! bw! Mystery solved. :cool:
Now I can move on, and learn more ... Thanks!
And thanks to everyone who has struggled to help me sort out this issue!
Michael :cool:
Delija
May 21, 2011 18:36 as a reply to  @ mikecox's post |  #13
I'm surprised that the LCD panel on the 60D is so much different than the one on the 7D :rolleyes:
Anyway, glad you got it straightened out...I'd have been very surprised if the camera were not showing info as it should. Things go wrong with anything made by humans, but when it comes to displaying info on an LCD....we've been able to buy LCD watches with a hundred functions for 30 years - this is something that I'd not expect to fail.
Peace,
D.
mikecox
Joined May 2011
May 21, 2011 18:59 |  #14
Delija wrote in post #12453971 (external link)
I was inclined to feel that same, that's why I was pretty sure it was a "user" issue ;)
Michael :cool:
2,264 views & 0 likes for this thread, 5 members have posted to it.
1316 guests, 160 members online
