Hi all,
I have a 20D, still a very fine camera.
Now im shooting raw since recent, so i have a question.
Which sharpening setting is best for my 20D in DPP? 3? 4?
Greetz
Reservoir_Dog Member 148 posts Joined Apr 2005 Location: Belgium More info | May 21, 2011 15:41 | #1 Hi all,
DavidRansley Senior Member More info | May 21, 2011 16:14 | #2 The setting depends on the result you want. There is no perfect setting as such, and you will need to look at the output each time. Start with three and see, but do try the "Unsharp Mask" option in the new builds. You will be amazed at what it does. DRH
whiteflyer Goldmember More info | May 21, 2011 17:00 | #3 Also remember that if you sharpen in the RAW tab, and then sharpen in the JPEG tab it adds them both up to give a LOT of sharpening.
tonylong ...winded More info | May 21, 2011 23:36 | #4 It also depends on 1) the subject matter, 2) the juggling act between sharpening and high ISO noise and 3) how it looks to you. View the image at 100% when sharpening, play around, and when you get a result that looks good to you then you are done! Tony
| Latest registered member is ealarcon 722 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
