I have a G3 and it seems that my focus assist light is no longer working. At least it's not turning on. I checked the camera settings in the menu and the lamp is set to "on" So now I have a couple questions
1. Has anyone else had this problem? Is there something I'm doing wrong it always turned on before. Could it be burnt out?
2 is this light used by the camera to focus or is it just there for the user to manually focus? If that's the case no big deal because I rarely manually focus.
Off this subject, I have a 420ex flash but I've noticed that when I use it my pictures are often slightly blurry. When using the onboard flash the pictures are sharp but the flash just washes everything out too much. I usually shoot in auto mode sometimes in program mode with the flash up for bounce ans also use the stofen omnibounce.
Any suggestions?
Kevin
