what are the pros & cons of symmetrical vs asymmetrical power distribution Elinchrom power packs?
Why would one use asymmetrical power pack?
picard Goldmember 1,996 posts Likes: 1 Joined Jan 2006 Location: Canada More info | May 22, 2011 03:54 | #1 what are the pros & cons of symmetrical vs asymmetrical power distribution Elinchrom power packs? Canon 1DM4,7D, Rebel XT
alessandro2009 Goldmember 2,095 posts Likes: 6 Joined Jun 2009 Location: Italy More info | May 22, 2011 06:00 | #2 |
May 22, 2011 09:44 | #3 thank you for the link. Canon 1DM4,7D, Rebel XT
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 22, 2011 14:36 | #4 Boy that Flickr link was obtuse! Let me explain it in simple terms... You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
May 22, 2011 16:45 | #5 Wilt wrote in post #12458147 Boy that Flickr link was obtuse! Let me explain it in simple terms... Symmetrical = power adjust to one channel affects ALL channels similarly Asymmetrical = ability to adjust power to one channel without affecting the other Example of the benefit of asymmetrical: You have two flash heads plugged into the same power pack. You want output ratio to be 2:1 (more light from Main head than from Fill head), rather than 1:1 (equal power from both heads). Asymmetrical permits you to easily adjust the Channel B head without impacting the amount of power from the Channel A head...I could put Channel B on half power while leaving Channel A on full power, to achieve 2:1 output from the heads. ah ok. Would asymmetrical power pack cost more money? Canon 1DM4,7D, Rebel XT
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 22, 2011 22:20 | #6 picard wrote in post #12458654 ah ok. Would asymmetrical power pack cost more money? I don't know of a manufacturer (no personal familarity) who makes both asymmetrical packs and also symmetrical packs of same total power, to compare one vs. the other in pricing! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
windpig Chopped liver More info | May 22, 2011 22:34 | #7 Pros of Ranger RX AS pack: 8.5 stops of power. Would you like to buy a vowel?
alessandro2009 Goldmember 2,095 posts Likes: 6 Joined Jun 2009 Location: Italy More info | May 23, 2011 01:41 | #8 picard wrote in post #12458654 Would asymmetrical power pack cost more money? Since they require a more sophisticated power management ...
Lichtwerk Goldmember 1,372 posts Joined Apr 2010 Location: Berlin, Germany More info | May 23, 2011 03:10 | #9 Wilt wrote in post #12458147 Boy that Flickr link was obtuse! Let me explain it in simple terms... Symmetrical = power adjust to one channel affects ALL channels similarly Asymmetrical = ability to adjust power to one channel without affecting the other Example of the benefit of asymmetrical: You have two flash heads plugged into the same power pack. You want output ratio to be 2:1 (more light from Main head than from Fill head), rather than 1:1 (equal power from both heads). Asymmetrical permits you to easily adjust the Channel B head without impacting the amount of power from the Channel A head...I could put Channel B on half power while leaving Channel A on full power, to achieve 2:1 output from the heads. That's not quite right. Asymmetrical (AS) packs won't necessarily let you control power independently. picard wrote in post #12458654 ah ok. Would asymmetrical power pack cost more money? Wilt wrote in post #12460338 I don't know of a manufacturer (no personal familarity) who makes both asymmetrical packs and also symmetrical packs of same total power, to compare one vs. the other in pricing! The Elinchrom Ranger RX Speed is available in both AS and symmetrical versions. Price is the same. Dennis
Cathpah Goldmember 4,259 posts Likes: 5 Joined Jan 2006 Location: Maine. More info | May 23, 2011 09:16 | #10 windpig wrote in post #12460428 Pros of Ranger RX AS pack: 8.5 stops of power. From incredibly low (using B channel) to incredibly high (using A channel). +1,000 Architecture
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 23, 2011 09:41 | #11 Lichtwerk wrote in post #12461644 That's not quite right. Asymmetrical (AS) packs won't necessarily let you control power independently. While some packs may feature independent power control for various ports on the pack, AS means that the power distribution is asymmetrical, 2:1 A:B in most cases. Some packs also give you the option to switch between symmetrical and asymmetrical ports, such as the Profoto Pro-B3. You still only have one power setting for the whole pack. Yes, my definition of 'control power independently' was not precisely right. But on the other hand, 'power distribution is asymmetrical, 2:1 A:B in most cases' may not be precisely accurate either (it fails to describe packs like Dynalite, which can do 1:1 even in asymmetric distribution). You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Lichtwerk Goldmember 1,372 posts Joined Apr 2010 Location: Berlin, Germany More info | May 23, 2011 10:56 | #12 |
May 23, 2011 13:33 | #13 when does one use the channel A head for the flash ? When should you use channel B ? Canon 1DM4,7D, Rebel XT
windpig Chopped liver More info | May 23, 2011 13:36 | #14 If you want the highest power, use A. If lowest power, use B. Would you like to buy a vowel?
kokakaste2 Goldmember 3,546 posts Joined Jan 2008 Location: Luxembourg More info | May 23, 2011 16:57 | #15 windpig wrote in post #12464100 If you want the highest power, use A. If lowest power, use B. exactly, or use B port when fast flash duration is important Oskar (Oscar) - stuff I use- Flickr
| Latest registered member was a spammer, and banned as such! 2799 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
