Thread started 23 May 2011 (Monday) 09:37
diffuser tips
denise69
May 23, 2011 09:37 |  #1
I am looking for a decent flash diffuser.
Anyone have any good suggestions?
Wilt
May 23, 2011 10:20 |  #2
Many threads on POTN about the limited usefulness of relatively small devices like Stoffen Omnibounce and Fong Lightsphere...they both rely upon availability of ceiling and/or nearby walls to serve as bounce surfaces, turning them into large virtual light sources. No walls, no ceilings, no use in using them -- unless your goal is to lose light and eat up batteries faster.
denise69
May 23, 2011 13:01 |  #3
Thanks for the input.
So here is my situational use for them.
Out side the high shool after graduation ceremony at dusk,
close to subject, looking to diffuse the harshness of a straight on-full force flash.....
SkipD
Joined Dec 2002
May 23, 2011 13:26 |  #4
denise69 wrote in post #12463889 (external link)
The plastic "diffusers" simply spread the available light into a wider area. They are not significantly larger than a bare flash, and thus there will be almost no softening of shadows when used in a place with no reflective surfaces to return the light from multiple angles.
What makes more sense if you are trying to soften the shadows outdoors or in very large venues (neither of which has nearby reflective surfaces) is using a large reflector to produce a significantly larger area to the effective "source" of the light. That reflector could be mounted on the flash unit or held by an assistant. The flash-mounted reflector could not be nearly as big as those handled by an assistant could be.
Understanding these points is easier if you understand the nature of light itself.
Skip Douglas
denise69
May 23, 2011 13:32 |  #5
I understand that.
I have a hand held reflector, however, I was shooting alone last weekend in a tight area outside. I was trying to avoid the straight on 'obvious flash look' of the photos.
I have diffuser, however, was given to me, I didn't purchase it. I am not completely familiar with diffusers and their qualities (significant or otherwise)
AntonLargiader
May 23, 2011 14:19 |  #6
There are some threads in the Flash forum demonstrating the effectiveness of certain diffusers/reflectors. Have you looked at the Lumiquest products?
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
gonzogolf
dumb remark memorialized
Gallery: 561 photos
May 23, 2011 14:25 |  #7
Rogue flashbender or demb flipit, both are bounce cards that you can fully adjust the angle. They can be used for partial bounce or bent forward so that all the light from the flash is redirected forward. They would probably have some effect at the distances you are working, but not more than 8 feet or so.
denise69
May 23, 2011 14:29 |  #8
GREAT! I will check out those products...that's what i am looking for, I believe. Close range work.
I appreciate your input!!!!
DC ­ Fan
May 23, 2011 16:41 as a reply to  @ denise69's post |  #9
Among the best flash diffusers is a conventiently-located white ceiling, assisted by a white card.
Point the shoe-mounted flash at the ceiling at a 75-degree angle. Put the white card behind the flash head so it protrudes a few inches and reflects some of the flash toward the subject. The result is smooth, diffused and shadow-free illumination, as shown above. The cost can be nothing, especially if you find a white card on a banquet table and use a rubber band to attach it to the flash head.
gonzogolf
Gallery: 561 photos
May 23, 2011 16:43 |  #10
Except she will be outside the gym, no ceiling to bounce off of.
denise69
May 23, 2011 16:43 |  #11
thanks for that tip!
:D
denise69
May 23, 2011 16:43 |  #12
gonzogolf, thanks, your right.
no ceiling!
Hermeto
May 23, 2011 19:43 |  #13
http://www.lumiquest.c​om/products.htm (external link)
http://www.dembflashpr​oducts.com/flipit/ (external link)
windpig
Chopped liver
May 23, 2011 20:00 |  #14
Get a 22" white reflector and have somebody hold it so you can bounce off of it. Try and stay 5 feet away from the subject.
Go ahead, spin the wheel.
denise69
May 24, 2011 08:47 |  #15
Like i mentioned earlier, i was shooting alone and i do have a reflector.
3,039 views & 0 likes for this thread, 9 members have posted to it.
diffuser tips
897 guests, 181 members online
