In manual mode how do you stop it down -1 1/3 I am not sure how to read or set the display to this?
picworx Goldmember 1,147 posts Likes: 4 Joined Jun 2005 Location: Ontario, Canada More info | May 23, 2011 15:09 | #1 In manual mode how do you stop it down -1 1/3 I am not sure how to read or set the display to this?
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | May 23, 2011 16:02 | #2 If you are going from full power. 1/1 the display will read 1/2 -.3. If turning the power up from 1/4 power it will read 1/4 +.7
thanks, some reason I am still confused what would the display show if I wanted say minus a 1 stop and 1/2?
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | May 23, 2011 17:43 | #4 The adjustment steps of the flash are in 1/3 stops. I do not remember if you can change to 1/2 stops or not. The difference between -1/3rd and -1/2 is not going to be very noticeable.
msowsun "approx 8mm" More info | May 23, 2011 21:07 | #5 These are really just "steps"of power, not "stops" of light. They could equal stops of light, but that would depend on the ISO and aperture you use as well. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
CliveyBoy R.I.P. He will be missed 3,272 posts Likes: 42 Joined Nov 2005 Location: Tauranga, NZ More info | May 23, 2011 21:16 | #6 From the manual: "You can set the flash output from 1/128 power to 1/1 full power in 1/3stop increments." Clive, and Great G/D Abbie
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | May 23, 2011 21:20 | #7 If you really want to split hairs on terminology I guess you can argue steps and stops. That still does not change the fact that when you go from 1/1 to 1/2 you reduce the light by 1 stop. Since there are 2 intermediate steps between those two values that works out to 1/3 stops. Just like when you click the wheel on your camera 3 clicks it changes the value by 1 stop. Each click is 1/3rd stop. The flash is the same.
msowsun "approx 8mm" More info | May 23, 2011 21:44 | #8 Of course you are right. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member was a spammer, and banned as such! 2799 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
