Thread started 24 May 2011 (Tuesday) 03:13
Off camera flash sync/shutter speed
cfvisuals
Joined Mar 2011
May 24, 2011 03:13 |  #1
It seems to me when I mount my 430ex on a receiver, my shutter speed can't go any faster than 1/250 of a second, if I do that I can see my shutter closing and creating a big patch of darkness on my photo. However fill flash works fine when I mLunt the flash on my camera, I can go any shutter speed I want.
Is it my trigger's problem or that's just how it is?
5∞ portfolio (external link)
Tiberius
May 24, 2011 03:26 |  #2
The problem is that you are hitting the camera's synch speed.
The shutter is made of two curtains. There is one covering the sensor, and another one up out of the way. When you take a photo, the first curtain moves out of the way to expose the sensor. Then, the second curtain drops in to cover the sensor again. The time that the second curtain waits is the actual shutterspeed. So if you shoot at 1/250, then the second curtain drops down 1/250 second after the first curtain does. In order for a flash to work, it needs to fire at a point where the entire sensor is exposed. it does this as soon as the first curtain is out of the way.
But the curtain only move so fast. And if you take a photo at a shutter speed faster that 1/250, the second curtain is starting to close before the first curtain has dropped all the way off the sensor. So, when the flash fires at the moment the first curtain is out of the way, the second curtain has already started to close. That means that the second curtain is stopping the light from the flash from reaching a part of the sensor. Only the ambient light (from before the flash fires) is registered by this part of the sensor. This is why you are getting the black bars - the ambient light isn't bright enough to produce an actual image, so it looks tremendously underexposed.
The reason why you can use any shutter speed when you have the flash on camera is because Canon flashes have a function called FP mode. It stands for Focal Plane (no idea why). What this mode does is pulse the flash several times instead of using just one big flash. That way it manages to cover the entire sensor, even though it is never completely exposed all at once. It's basically filling in the black bars with a second flash. The downside to this is that you lose a bit of flash power. This mode is what's letting you get the faster shutter speeds. Have a look at the screen on your flash. I bet in the top center you have a lightning bolt with an H next to it. That's the FP mode, or high speed synch.
When you have your flash mounted on a radio receiver, the flash is only getting the signal "Fire now!" when the first curtain is completely out of the way. it doesn't know that the second curtain has already covered part of the sensor.
Unfortunately, that's how it is. You can use the wireless system built into Canon's flashs to enable FP mode with an off camera flash. You'll need to buy a master unit for the camera. I recommend a 580EX. You might be able to get a second hand mark 1 for pretty cheap. Look on ebay.
My photography website!PHOCAL PHOTOGRAPHY (external link)
angryman
Joined May 2011
May 24, 2011 07:25 as a reply to  @ Tiberius's post |  #3
what he said.
Angryman Photography & Design (external link)
suecassidy
May 24, 2011 09:52 |  #4
Does the 430 ex have high speed sync mode? If it does, you can shoot higher than sync speed, but I dont' know the specs on that flash.
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
dedsen
May 24, 2011 10:39 |  #5
suecassidy wrote in post #12469335 (external link)
Only if the flash is mounted in the hot shoe, being controlled off camera with a Canon master flash or the newest Pocket Wizards. HSS does not work with most wireless triggers.
scroller52
May 24, 2011 12:13 |  #6
time to read the flash manual.
Canon EOS 5D3 | Canon 24mm 1.4L mkII | Canon 85mm 1.2L mkI | Canon 40mm 2.8
my flickr (external link)
my picasa (external link)
The ­ Outlaw
May 24, 2011 12:19 |  #7
Tiberius47 wrote in post #12468156 (external link)
does ettl work wirelessly like this also? if so can it also be done with a canon mr-14ex? i knew i could use the ringflash to trigger my 430ex but thought it had to be in manual mode. if i could have used it for ettl im really going to regret that i sold it a couple of weeks ago.
Nothing to see here....
ScullenCrossBones
May 24, 2011 12:35 |  #8
The 580EX can be used to trigger the 430EX wireless ettl but it's infared so range and conditions are limited.
:p Gear
Mama done took my Kodachrome away...
Madweasel
May 24, 2011 12:51 |  #9
The Outlaw wrote in post #12470211 (external link)
Yes, the MR-14EX and the MT-24EX macro lites can both perform as a master in Canon's E-TTL II system.
Mark.
HughR
May 24, 2011 15:49 |  #10
The ST-E2 also triggers off camera flash wirelessly, as do the pop-up flashes on the 60D, 7D, and T3i. However, these off-camera solutions do not permit high speed sync and are limited to the max flash sync speed (eg. 1/250 sec on the cameras listed above). That is true even when using ETTL, which I do all the time with my 430EX on my 60D. The 430EX will do high speed sync when on camera. However, high speed sync drains the batteries quickly, slows recycle times, and reduces the maximum amount of light the flash can produce. I basically never use high speed sync.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
cfvisuals
Joined Mar 2011
May 24, 2011 16:06 |  #11
scroller52 wrote in post #12470175 (external link)
If you aren't contributing to thread, why waste your time typing?
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 24, 2011 16:46 |  #12
I like both an explanation and a visual. Even though this a PW ad the first 3 minutes has a great animated explanation. This really helped me out.
http://www.pocketwizar​d.com …wizard_controlt​l_optimiz/ (external link)
Image Editing OK
Tiberius
May 24, 2011 17:35 as a reply to  @ digital paradise's post |  #13
The Canon wireless system supports ETTL.
ScullenCrossBones wrote in post #12470335 (external link)
The 580 as a master uses pulses of visible light, not infrared, to control slaves. The range is also pretty good. I can easily get ten meters with mine, and for portrait light setups that's more than enough.
ScullenCrossBones
May 24, 2011 19:04 |  #14
I think I knew that now that you corrected me. Thanks.
:p Gear
yogestee
May 24, 2011 19:52 |  #15
Yep,, that's the first thing I do when I have a problem or there's something I don't understand about my camera..
Also, in these forums, there are probably dozens of threads like, "Why do I get a black band on the bottom of my photos when using flash", or words to that effect.
The search tab is your friend :D
Jurgen
3,334 views & 0 likes for this thread, 13 members have posted to it.
2799 guests, 149 members online
