I have read how to use a grey card, but how close, or far away do you actually use it from the lens. I would like to know from actual users of the card. Thanks, Stephen.
1shot4u Goldmember ![]() 1,568 posts Joined Apr 2008 Location: Augusta, Ga More info | May 24, 2011 08:21 | #1 I have read how to use a grey card, but how close, or far away do you actually use it from the lens. I would like to know from actual users of the card. Thanks, Stephen. Stephen Shell
zerovision Goldmember ![]() 1,204 posts Likes: 3 Joined Aug 2008 Location: Dallas/Ft Worth area More info | May 24, 2011 08:30 | #2 I use them as much as possible and have read, seen and had success when the card takes up most, but not all of the picture. All the top pros I've heard from say that you should expose part of the background so you get more of the light you are metering.
dmward Cream of the Crop More info | May 24, 2011 09:10 | #3 If you are using it for custom white balance in the camera, then follow the instructions in the manual. David | Sharing my Insights, Knowledge & Experience
May 24, 2011 09:20 | #4 dmward wrote in post #12469129 ![]() If you are using it for custom white balance in the camera, then follow the instructions in the manual. If you are including it in the shot so you can use white balance eye dropper in post processing it can be much smaller, but I would still do a separate shot with the gray card just for insurance. I presume you are using a digital gray card that is neutral, rather than a photographic gray card that is intended as a reflective light metering aid and may be way off for white balance. Where does one obtain this "digital" gray card? Never heard of it. Lightbender57
TMR Design Cream of the Crop ![]() 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Hi Stephen, Robert
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] ![]() More info | May 24, 2011 10:44 | #6 Some (but not all) cards are neutral (equal values of R-G-B) and can be used for White Balance. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
dmward Cream of the Crop More info | May 24, 2011 11:10 | #7 Wilt said it. David | Sharing my Insights, Knowledge & Experience
May 25, 2011 11:40 | #8 I downloaded a "Grey Kard" app for the iPhone and iPad but I'm skeptical of how to use it. http://www.avidchick.com
TMR Design Cream of the Crop ![]() 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | May 25, 2011 11:41 | #9 nathancarter wrote in post #12476629 ![]() I downloaded a "Grey Kard" app for the iPhone and iPad but I'm skeptical of how to use it. It seems like it would be unreliable for both metering and white balance, since the device gives off its own light instead of solely reflecting the ambient light. Thoughts? Fun toy. Bad idea. Robert
May 25, 2011 11:54 | #10 TMR Design wrote in post #12476636 ![]() Fun toy. Bad idea. That's kinda what I thought. http://www.avidchick.com
PhilF Cream of the Crop ![]() 5,737 posts Likes: 608 Joined Jan 2010 Location: Valencia, CA More info | May 25, 2011 13:48 | #11 TMR Design wrote in post #12469183 ![]() Hi Stephen, The gray card is placed or held at subject position and in the exact light that falls on (and bounces off) your subject when you're shooting. Distance from the lens doesn't matter. Correct exposure absolutely matters. If you're using the gray card to set an in-camera custom white balance then you want to either fill the frame or at least fill a large central portion of the frame. If you're using the gray card as a reference to be used in post production then you don't need to worry about the size of the card in the frame but you do still have to make sure it's properly exposed and in the same light as the subject. what he said. http://philfernandezphotography.com
May 27, 2011 13:08 | #12 Thanks everyone for your thoughts and ideas. After considering all the info, I'm going with TMR Design and give it a try. Again thanks to all....this is a great forum to get real user help and ideas. Stephen. Stephen Shell
y 1600 |
Log in Not a member yet?
Latest registered member is sinonaut 824 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
