Thread started 24 May 2011 (Tuesday) 15:00
LED buld for Alien Bees modelling light?
bobbyz
May 24, 2011 15:00 |  #1
I know David Hobby mentioned using LED bulb in this AB when used on location with vagabond.
Would something like this work:
http://www.ledwholesal​ers.com …ct=viewProd&pro​ductId=686 (external link)
I just need something for AF assist during late evening shoots.
Fuji XT-1, 18-55mm
SkipD
Joined Dec 2002
May 24, 2011 15:12 |  #2
I would not expect that bulb to be worth a hoot as a modeling light. This is because it probably cannot be dimmed the way a standard bulb can.
You can simply turn off the modeling light circuit when working with the Vagabond as your power supply.
Modeling lights in AB flash units aren't bright enough to use effectively except in a dimmed-light studio environment anyway.
For strictly use as a focus assist, I'd probably use a separate lamp that's a bare bulb with an efficient reflector (such as a clip-on shop light) to make it as bright as practical. For that, the LED bulb would probably give you enough light while not putting much load on the Vagabond.
Skip Douglas
1,609 views & 0 likes for this thread, 2 members have posted to it.
2799 guests, 149 members online
