I love the look I can get with Silver EFX Pro but I'm starting to think the noise this program adds to images could be a deal breaker. Any one else notice the noise ?
May 25, 2011 08:54 | #1 I love the look I can get with Silver EFX Pro but I'm starting to think the noise this program adds to images could be a deal breaker. Any one else notice the noise ? Paul
May 25, 2011 08:58 | #2 Yep, sure do, I usually run Define right after to clean up the noise..havent really paid to much attention as to what setting is causing it though.. EOS 6d, 7dMKII, Tokina 11-16, Tokina 16-28, Sigma 70-200mm F/2.8, Sigma 17-50 F/2.8, Canon 24-70mm F/2.8L, Canon 70-200 F/2.8L, Mixed Speedlites and other stuff.
NinetyEight "Banned for life" More info | May 25, 2011 09:17 | #3 I tend to use the program as it is intended(?) and actually want the film grain effect. I know 'noise' is not the same as grain, but it tends to be irrelivant in this situation. Kev
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | May 25, 2011 09:22 | #4 kbColorado wrote in post #12475630 ...Any one else notice the noise ? No. I've been using SilverEfex Pro for nearly 3 years and do lots of B&W. Chas P
IslandCrow Senior Member 589 posts Likes: 1 Joined Oct 2008 Location: Rapid City, SD More info | May 25, 2011 10:53 | #5 Same here, I haven't noticed any additionaly noise unless it's put in there intentionally, either by me, or if I'm using one of the pre-defined styles. Personally, I almost always add at least a touch of noise, though. B&Ws that are too "silky smooth" just look a little wrong to me most of the time.
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | May 25, 2011 11:09 | #6 Never had any noise, though if you push sensitive areas too hard, like skies, you may get posterization/banding depending on shot settings or if the camera simply isn't up to the task. 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 36 Joined Jun 2003 Location: Trantor More info | May 25, 2011 12:52 | #7 kbColorado, .
Since my limited experience is with the Silver EFX Pro presets, and the presets I prefer are pretty extreme ... the Film Noirs, for example ... I'll look into using it with more control over the image. crocus black and white Paul
pbelarge Goldmember 2,837 posts Joined Jun 2010 Location: Westchester County, NY More info | Paul just a few of my thoughts...
pbelarge Goldmember 2,837 posts Joined Jun 2010 Location: Westchester County, NY More info | May 26, 2011 09:23 | #10 ChasP505 wrote in post #12475812 No. I've been using SilverEfex Pro for nearly 3 years and do lots of B&W. But it's easy enough to induce noise if you want to, or emulate film grain. Are you editing, resizing, or compressing your images in any way before doing the B&W conversion in SilverEfex? Shooting at excessively high ISO? Lots of noise in color images goes undetected, but gets magnified in B&W.
macroshot Stuck by a stickie 2,983 posts Likes: 8 Joined Sep 2007 Location: nacho cheese More info | Personally, the only thing I might do prior to opening SEP2 is crop. If you happen to have the full suite, Nik suggests the workflow start with Dfine for noise reduction before moving to Silver Efex. I don't know if that applies to LightRoom NR as well. I photograph to find out what something will look like photographed.
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | May 26, 2011 10:06 | #12 pbelarge wrote in post #12482257 Should one not perform any editing before converting? Such as sharpening/NR/cropping in the original performed in LR Do whatever you want... Experience with the software (or ANY method of BW conversion) will help you predict the results. Chas P
Another helpful point ... yes, the images I've worked with in this software have been messed around with in LR first. I'll keep that in mind. And to macroshot ... I don't waste my time on turds polished or otherwise Paul
District_History_Fan Goldmember 2,286 posts Likes: 1 Joined Dec 2008 More info | Jun 01, 2011 07:22 | #15 kbColorado wrote in post #12475630 I love the look I can get with Silver EFX Pro but I'm starting to think the noise this program adds to images could be a deal breaker. Any one else notice the noise ? The "structure" slider is a local contrast adjustment. Its a wonderful tool but can add definition to an already noisy image (particularly noticeable in the sky). Is this what you are referring to?
| Latest registered member is griggt 1439 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
