Thread started 25 May 2011 (Wednesday) 21:51
Strobe matching advice for 430exii
afoord82
Joined May 2011
May 25, 2011 21:51 |  #1
I have a 430 ex ii and I would like to pair it with another light source. I have reflectors and such, but want something as a backlight thats not too expensive. Also wondering if I could use my 430 ex wirelessly as a master to the other strobes. under $200 would be great, under 150 would be ideal.
C.Michael
May 25, 2011 23:58 |  #2
AFAIK, the only Canon EX range flash to have master capabilities is the 580EX (II).
www.christophermorriso​n.com.au (external link)
Canon 5D Classic w/ grip | 50mm f/1.8 | 85 f/1.8 | 430EX II + YN460II
Frogday
May 26, 2011 00:11 |  #3
C.Michael wrote in post #12480790 (external link)
550EX will also work as master.
5D MIV | 5D MII | 7D | 30D | D30 | A2E | Elan 2e | AE1p | FTb | SD1100IS | G7x
EF 85 F1.8 | EF 100 F2.8 macro | EF-S 15-85 IS
EF 24 F1.4L II | EF 35 F1.4L | EF 85 F1.2L II | EF 135 F2.0L | EF 8-15 F4L | EF 11-24 F4L | EF16-35 F2.8L II | EF 24-70 F2.8L | EF 24-70 F2.8L II | EF 70-200 F2.8L IS II
Frogday
May 26, 2011 00:13 |  #4
afoord82 wrote in post #12480133 (external link)
YN-560 are $60ish and would trigger optically, though they don't do ETTL.
C.Michael
May 26, 2011 00:29 |  #5
Frogday wrote in post #12480849 (external link)
Ah yes, for some reason I thought it was an EZ!
Cheers!
afoord82
Joined May 2011
May 26, 2011 01:53 |  #6
thank you all for the advice... i dont mind a manuakl flash, I just want to have more than 1 flash and be abl to fire them all wirelessly.
Blurr ­ Cube
...a lucky id-iot that didn't get electrocuted...
May 26, 2011 11:11 as a reply to  @ afoord82's post |  #7
Look into radio triggers. YN or Cactus or PW, etc.
| Canon EOS Systems |
HughR
May 26, 2011 12:14 |  #8
If you have a 60D, 7D, or T3i, you can fire the 430EX wirelessly using ETTL from the camera's pop-up flash. Otherwise you need the 530, 580, or the ST-E2.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
gonzogolf
dumb remark memorialized
Gallery: 561 photos
May 26, 2011 12:16 |  #9
HughR wrote in post #12483302 (external link)
550ex, 580EX, or 580ExII.
afoord82
Joined May 2011
May 26, 2011 20:55 |  #10
yes I have a radio trigger already, if I were to buy another flash, would I be able to set my 430ex as a slave as well as the others and have them all fire?
Blurr ­ Cube
May 26, 2011 21:15 |  #11
afoord82 wrote in post #12486041 (external link)
Which radio triggers?
Transmitter on the camera. Each flash on a receiver. So that's a total of 3 units (more for any added flash). Set all at the same channel and each flash should fire simultaneously.
| Canon EOS Systems |
afoord82
Joined May 2011
May 27, 2011 13:59 |  #12
its just a cheap wein radio trigger with 1 receiver.
gonzogolf
Gallery: 561 photos
May 28, 2011 18:59 |  #13
afoord82 wrote in post #12490001 (external link)
The 430ex only slaves using the canon wireless system, so you would need a receiver to match your trigger.
2,187 views & 0 likes for this thread, 6 members have posted to it.
2769 guests, 157 members online
