vtecsilver wrote in post #12509651
If you crop an image taken on a 5D II to produce an image equivalent to what a crop sensor captures, how many pixels would the image end up having (effectively cropping the 5D II image to get the "1.6x zoom effect" of a crop sensor)?
I may be off on the exact math, but I believe if you take the 5d2's 21mp and crop down to the 1.6 FoV, you'd only get like 8.5mp worth of image. You take a significant hit in "magnification" (due to pixel density). This is the main reason why the 5D2 has such a superior ISO noise (lack-of) advantage over crops. Where as in that same 8.5mp crop, the 7D (60D/T2i/T3i) gives you 18mp.
If you're just shooting jets (w/o care for prop blur), then I think the 5d2 will be more than sufficient if you have a long enough lens. You won't really depend on the FPS as much. However, if you'll be shooting more prop planes and want to capture prop-blur to give that sensation of motion/flight (and not just some model plane thrown up in the air), then the FPS will help provide you with higher keeper rates as you track and pan. That's been my personal experience when I'm at airshows.
(I believe these two were un-cropped if memory serves me right.)
