Thread started 27 May 2011 (Friday) 10:33
Constantly leaving my batteries in the charger
samueli
Gallery: 11 photos
May 27, 2011 10:33 |  #1
I left a battery on all night, and now consequently all day since I'm at work. It's no wonder my batteries don't last for squat. I wish canon would have their chargers switch off whent he battery is full. Every battery I forget about gets ruined, and lasts not even a 1/4 of what it did if I accidentally leave it on for a long time.
Just shoot me...
Unregistered.Coward
May 27, 2011 10:44 |  #2
While I've never had an issue with inadvertently leaving a battery in the charger, you can remedy your problem with a simple timer
http://www.amazon.com …B003P2UMS0/ref=​pd_cp_hi_3 (external link)
....the best camera is the one you have on you at the time.
samueli
Gallery: 11 photos
May 27, 2011 10:54 as a reply to  @ Unregistered.Coward's post |  #3
Thank you very much for the suggestion! I have several of these laying around. Now if I only had a brain...
Saint728
May 27, 2011 13:22 |  #4
Not sure what camera batteries you have or charger, but mine turns off when its charged. Also lithium ion batteries don't have a memory. Maybe your batteries are too old and need to be replaced?
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
gjl711
"spouting off stupid things"
May 27, 2011 13:24 |  #5
Saint728 wrote in post #12489814 (external link)
..Also lithium ion batteries don't have a memory. Maybe your batteries are too old and need to be replaced?
Though true the Li-ion batteries have no memory, they do not like to be constantly charged. Li-ion batters degrade quickly when heated and charging makes them hot. It won't kill them right away, but will significantly reduce their lifespan.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
gjl711
May 27, 2011 13:26 |  #6
This is a very nice write up on Li-ion batteries and battery life.
http://batteryuniversi​ty.com …g_lithium_based​_batteries (external link)
::Gear::
samueli
Gallery: 11 photos
May 27, 2011 13:42 as a reply to  @ gjl711's post |  #7
They are all 50d style batteries, either OEM or aftermarket, and a couple are barely a year old. I often leave them on by accident for anywhere between 12 hours to several days. I do not like the idea that they continue to charge once they are full. I need a ronco battery charger, "set it and forget it!".
samueli
Gallery: 11 photos
May 27, 2011 13:45 |  #8
gjl711 wrote in post #12489842 (external link)
Wow, didn't know batteries lose that much permanently in a years time, just through storage.
gjl711
May 27, 2011 13:54 |  #9
Yup, Li-ion batteries are a different beast. I have since reading about these, and having a very interesting discussion with a power engineer here at work, modified my usage of the batteries. I no longer fully charge them nor let them run totally empty. I also store them with a partial charge and charge them when headed out to a shoot. I haven't gone the route of refrigerating them though I was told that keeping them cold greatly increases their life span. That's just too much.
::Gear::
Wilt
May 27, 2011 14:27 |  #10
I don't recommend simply relying on a timer to interrupt AC power input in the charger, the battery can discharge back into the charger...much better to set an alarm to remind you to remove the battery from the charger!
1,443 views & 0 likes for this thread, 5 members have posted to it.
644 guests, 120 members online
