Thread started 28 May 2011 (Saturday) 08:43
Help - Adobe Bridge CS5
IanW
Gallery: 27 photos
Joined Nov 2005
May 28, 2011 08:43 |  #1
Please help, my workflow does not seem to be quite right.
I have Adobe Photoshop CS5 which I love, it comes with Adobe Bridge which I also like but seem to have a problem with. When I look at my images through Bridge (Preview or Review) they are always VERY soft and hard to tell if they are in focus or not. I do a lot of motorsport photography which results in lots of OOF shots, I need to be able to fly through the 1000 or so images quickly to remove all the OOF shots. I then go through the images again to rate the keepers and decide which to PP.
Because I cannot see well enough the quality of the images in Bridge, I am using DPP to pass through the images to bin the OOF and then rate the keepers. I then move to Bridge to find the rated images and then PP in ACR and PS CS5.
The workflow works but does not feel right. Is there something not right with my Bridge, am I doing something wrong, or is the image quality just not 100%?
Any help and advice is greatly received.
Thanks,
Ian.
Canon 5DIII | BG-E11 | Laowa 100mm f2.8 APO 2:1 Macro | 24-105mm f4L | 70-200mm f2.8L IS II | 100-400mm f4.5-5.6L IS II | x1.4 & x2 III | 430EX Godox TT600 | Yongnuo YN-622C | Kenko Tubes | LEE Filters | Manfrotto 055CXPRO3+498RC2+454, 694CX
Instagram (external link)
PixelMagic
May 28, 2011 09:40 |  #2
Does this also happen if you press the Space Bar to preview the image in full screen mode? Or use CTRL + L to view them as a slideshow?
S.Horton
May 28, 2011 09:54 |  #3
Use Filmstrip view (Window -> Workspace -> Filmstrip)
Make the thumbs at the bottom fairly small, and reduce the size of the info pane at left, then as you scroll through them in the thumbnail bar at the bottom (the filmstrip) you will see a decent size preview in the middle of the screen.
For all folders, I point bridge to the folder, then wait until the progress of generating previews, shown lower left, is complete, before I start doing work.
Sam - TF Says Ishmael
:cool:
IanW
Gallery: 27 photos
Joined Nov 2005
May 28, 2011 11:09 |  #4
PixelMagic wrote in post #12493922 (external link)
Yes
S.Horton wrote in post #12493982 (external link)
Still no good.
I will try to attach some screen grabs so you can see the difference. Attached are two screen shots from Bridge, one is SPACE preview, the other is FILMSTRIP.
Ian.
IanW
Gallery: 27 photos
Joined Nov 2005
May 28, 2011 11:10 as a reply to  @ IanW's post |  #5
Screen grab from DPP Quick Check.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 28, 2011 11:13 |  #6
IanW wrote in post #12493753 (external link)
Thanks,
Ian.
Hmm. I have the same issue. The images in DPP always look so great. I just check the OOF images with #1, then I call them up, select the first and last and delete them all. Like you I go through it a second time. A little cumbersome but I just love how they look in DPP.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
May 28, 2011 11:13 |  #7
I'll give that a try.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
May 28, 2011 11:23 |  #8
I forgot to mention Ian. After deletion I go through them again and tag any images that need a little extra work besides a global recipe. I call up the extra adjustment tags, fix them and when done I delete those tags. I open and close any file which sends them back in order. Since there are missing files I then use the rename tool which you probably already know about.
Image Editing OK
tkerr
May 28, 2011 13:00 |  #9
How do you have the Options for thumbnail quality and preview generation set?
Tim Kerr
F1, try it you'll like it.
S.Horton
May 28, 2011 16:36 |  #10
Yes, check your preview settings, and whether or not you are applying sharpening to previews.
:cool:
cmchavis
May 29, 2011 00:08 as a reply to  @ S.Horton's post |  #11
According to Kelby - http://www.photoshopus​er.com/lightroom (external link) - their #1 reason to use lightroom over bridge is that Bridge will not generate a sharp full screen preview.
So it might be something inherent to Bridge. YMMV.
bryno74
May 29, 2011 00:27 |  #12
Photo Mechanic is the best for what your trying to do.
EOS-1D Mark III - 70-200 2.8 - 300mm 2.8L IS - 580EX II
http:// …
IanW
Gallery: 27 photos
Joined Nov 2005
May 29, 2011 01:26 |  #13
tkerr wrote in post #12494755 (external link)
I have "Always High Quality" and "Generate 100% Previews" ticked.
S.Horton wrote in post #12495530 (external link)
What other settings are there for Preview?
So just to confirm are there people out there who ARE happy with the sharpness and quality of Bridge Preview?
Ian.
IanW
Gallery: 27 photos
Joined Nov 2005
May 29, 2011 01:28 |  #14
cmchavis wrote in post #12497362 (external link)
I did wonder if this was the case, great, more money!! :rolleyes:
I think I will stick with DPP for review and rating then move to Bridge, ACR and CS5.
Ian.
tkerr
May 29, 2011 04:00 |  #15
Bridge applies no automatic Development to the images. What you are seeing is the Raw image, no sharpening, NR, etc. However you can select all the images you want to review, and than apply Camera Raw Defaults or any preset you like.
Edit / Develop Settings.
Tim Kerr
6,450 views & 0 likes for this thread, 10 members have posted to it.
Latest registered member is vinceisvisual
940 guests, 175 members online
