Thread started 28 May 2011 (Saturday) 09:13
Using a flash bracket
TiaS
May 28, 2011 09:13 |  #1
I would like to get a flash bracket. Is there certain ones that work with different flashes? Also do I need to wire my flash to my camera.... and if so, how does that work?
Jim ­ M
May 28, 2011 09:44 |  #2
Flash brackets all attach the the flash in pretty much the same way, namely a cold shoe mount (same as a hot shoe, but without any electrical connections. You will need a cord to connect the flash to the camera. I use a FlashZebra ETTL cord. It seems every bit as good as the more expensive Canon ETTL cord that costs much more. Put the flash in the ETTL cord shoe, mount the ETTL shoe on the flash bracket, then mount the other end of the ETTL cord on the camera's hot shoe. You can also make the connection with a PC cord if your flash and camera will accept them mounting the flash directly on the bracket, but you will have no ETTL. Here is a link to FlashZebra:
http://flashzebra.com/​products/0122/index.sh​tml (external link)
sapearl
Gallery: 243 photos
May 28, 2011 09:47 |  #3
You may want to check out the Newton products:
https://photography-on-the.net/forum/showthre​ad.php?t=338933
They are very compact, lightweight, work as advertised, versatile and quite pricey. They are perfect for heavy duty use. If you are just doing occasional use, you may want to consider an inexpensive stroboframe instead.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
TXLEBER
May 28, 2011 09:52 |  #4
Custom Brackets (external link)
RPCrowe
Joined Nov 2005
May 28, 2011 10:06 as a reply to  @ TXLEBER's post |  #5
You "may" be able to use a flash bracket without an off-camera cord "if" you are using a camera which allows wireless flash such as the 60D, 7D and some of the later Rebels. However, using the flash mounted on a bracket when shooting outdoors is a bit tricky. Your wireless sync will not always work and its capability will depend on the angle and intensity of the sun and the subject to camera distance. Using the off-camera cord is the best idea.
As for flash brackets...
I prefer a camera-flip bracket to a flash-flip bracket. While both flash-flip and camera flip brackets are designed to keep the flash directly over the lens when shooting in either the landscape or portrait position; the flash-flip version will require the reorientation of the flash unit when switched from landscape to portrait when you are BOUNCING the flash. AND I ALWAYS BOUNCE. The camera-flip bracket will not require the changing of the flash orientation.
IMAGE: http://rpcrowe.smugmug.com/Other/Photo-Equipment/i-BDsrRmW/0/L/Bracket-FLASH-FLIP-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …H#1304495185_BD​srRmW-A-LB  (external link)
IMAGE: http://rpcrowe.smugmug.com/Other/Photo-Equipment/i-V99r5dH/0/L/Bracket-Camera-Flip-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …H#1304495186_V9​9r5dH-A-LB  (external link)
Wilt
May 28, 2011 10:28 |  #6
And please take note in the example shots by RPCrowe, that ...
  • the camera grip ends up on the bottom side in Portrait orientation for some brackets, defeating the availability of the supplemental control buttons on a battery grip.
  • And many brackets cannot accomodate well a camera with a battery grip, because of the added height of the camera+grip.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 28, 2011 10:31 |  #7
I went with this one. The next one is better but heavier. Both solid builds but it depends on how much you want to spend. You will need some additional brackets with these.
http://reallyrightstuf​f.com …ket-with-QR-Flash-Adapter (external link)
http://reallyrightstuf​f.com …-Perfect-Package-(Medium) (external link)
Image Editing OK
Wilt
May 28, 2011 10:35 |  #8
Newton, RRS, and Custom Brackets are the three on the market that are good enough for meeting the demands of professionals...with cost to fit! Lesser brackets generally sacrifice in one area or another, whereas these three meet all demands...'you get what you pay for' in action once again.
RPCrowe
Joined Nov 2005
May 28, 2011 11:23 as a reply to  @ TXLEBER's post |  #9
You "may" be able to use a flash bracket without an off-camera cord indoors "if" you are using a camera which allows wireless flash such as the 60D, 7D and some of the later Rebels. However, using the flash mounted on a bracket when shooting outdoors is a bit tricky. Your wireless sync will not always work and its capability will depend on the angle and intensity of the sun and the subject to camera distance. I consider using the off-camera cord is the best idea.
I use a Stroboflash bracket and I prefer a camera-flip bracket to a flash-flip bracket. While both flash-flip and camera flip brackets are designed to keep the flash directly over the lens when shooting in either the landscape or portrait position; the flash-flip version will require the reorientation of the flash unit when switched from landscape to portrait when you are BOUNCING the flash. AND I ALWAYS BOUNCE. The camera-flip bracket will not require the changing of the flash orientation.
The bracket shown in the above illustrations is a Chinese knockoff of a Stroboframe. It is a combination flash-flip and camera-flip model. I have switched to a Stroboflash camera-flip bracket because I like to carry my rig (which is fairly heavy) around by using the flash bar as a handle, The flash bar of my Stroboframe bracket (I bought the bracket for under twenty bucks used on eBay, that price included shipping) is solid and doesn't tilt. It makes a more solid hold.
BTW: I normally use the flash bracket in combination with a Joe Demb Flash Diffuser Pro www.dembflashproducts.​com (external link) . IMO, the lighting produced by this combination of bracket, bounced flash and Flash Diffuser Pro is great...
IMAGE: http://rpcrowe.smugmug.com/photos/1245211383_X7dDz-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …LJM#1245211383_​X7dDz-A-LB  (external link)
IMAGE: http://rpcrowe.smugmug.com/photos/i-JrkG2Ch/0/L/i-JrkG2Ch-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …M#1281579394_Jr​kG2Ch-A-LB  (external link)
TiaS
May 28, 2011 22:53 |  #10
RPCrowe, thanks for the demonstrations!
pbelarge
Joined Jun 2010
May 28, 2011 23:17 as a reply to  @ TiaS's post |  #11
Yes, you will need either a wireless or corded method of attachment for your flash.
This is the bracket I have and really like the flexibility it offers, as well as ease of use.
http://www.bhphotovide​o.com …unior_Flash_Rot​ating.html (external link)
I notice that it went up like $30 since I purchased it. :eek:
just a few of my thoughts...
Pierre
thebishopp
May 29, 2011 04:38 |  #12
I have an expensive flash bracket (Customer Brackets) that stays in the studio because it is so dang heavy my arm feels like it is falling off after a long night, heck after only a couple hours into a night. I've been using an inexpensive ebay one for about 3 years now and it is just fine. I liked it so much I bought a 2nd one for backup (which is still backup because the first one is still working).
Here is the one I am using:
http://cgi.ebay.com …m56439ff879#ht_​1994wt_905 (external link)
"Please use the comments to demonstrate your own ignorance, unfamiliarity with empirical data, ability to repeat discredited memes, and lack of respect for scientific knowledge. Also, be sure to create straw men and argue against things I have neither said nor even implied. Any irrelevancies you can mention will also be appreciated. Lastly, kindly forgo all civility in your discourse . . . you are, after all, anonymous." My Zen (external link)
Wilt
May 29, 2011 09:26 |  #13
thebishopp wrote in post #12497924 (external link)
Yes, weight...the best Custom Brackets in their line weigh about 1 pound more than a Newton!
digital ­ paradise
Gallery: 157 photos
May 29, 2011 09:36 |  #14
It does make a difference. The RRS bracket is only 11 ounces which is not much at first but by the end of the day.
Image Editing OK
airbutchie
Not too crunchy
Gallery: 413 photos
Best ofs: 7
May 29, 2011 09:37 |  #15
I had the same concerns/questions when I was looking into a flash bracket and found this wonderful thread by ben_r... Needless to say, after all the research I went wit an RRS system... The investment was worth all the pennies... Here's the thread: https://photography-on-the.net/forum/showthre​ad.php?t=544273
Hi. My name is Butch...
3,992 views & 0 likes for this thread, 10 members have posted to it.
2769 guests, 157 members online
