Thread started 28 May 2011 (Saturday) 09:18
Is there a flash that has a power strength button on it?
TiaS
May 28, 2011 09:18 |  #1
I have my little flash for indoor use, but sometimes when I am outdoors I need more reach and sometimes I don't. My subject will move close or far away, depending on the shot. If they are too close, than my flash is too powerful and if they are too far, than the flash doesn't reach. Is there a flash that I can adjust the power without having to go into my camera settings and set flash exposure compensation for each shot?
sapearl
Gallery: 243 photos
May 28, 2011 09:22 |  #2
I know that the higher end Canon flash units allow you to manually set decreased flash output....1/2, 1/4, etc..... likely so do the Metz, Quantum and a lot of others. Also, on the 580ex you can dial in " - FEC ".
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
SkipD
Joined Dec 2002
May 28, 2011 09:28 |  #3
TiaS wrote in post #12493841 (external link)
I have my little flash for indoor use,....
What is your "little flash" unit?
If you are using one of the appropriate Canon Speedlites, you really shouldn't have any problem when using it in ETTL mode.
Skip Douglas
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
May 28, 2011 11:02 |  #4
sapearl wrote in post #12493850 (external link)
You can even to it in thirds between stops on the Canon 580's.
Image Editing OK
zacm7
May 28, 2011 11:08 as a reply to  @ digital paradise's post |  #5
vivitar 285HV is probably one of the best manual flash units you can buy..,they still produce them new overseas and they are 100 bucks on ebay
inkista
May 28, 2011 16:05 |  #6
zacm7 wrote in post #12494367 (external link)
Uh. Missing 1/8 power setting, only goes down to 1/16, no swivel capability, and proprietary sync connector. No built-in optical slave. It was the best, but today thanks to David Hobby passing out the Strobist kool-aid, there are better choices.
My Yongnuo YN-560 has all the settings from full down to 1/128, 270ยบ swivel, and a PC sync connector. WITH a built-in optical slave that can recognize both manual and TTL flash bursts. $70 on Amazon. The $160 Lumopro LP-160 goes one better by adding a 3.5mm minijack sync port.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
Bula ­ Matali
Jun 01, 2011 04:26 as a reply to  @ inkista's post |  #7
Nissen flashguns
msowsun
"approx 8mm"
Gallery: 18 photos
Jun 01, 2011 07:17 |  #8
Any "Auto" or "ETTL" flash will do what you want. It will do it automatically without pushing any buttons.
In the mean time you just need to adjust the camera ISO, and aperture to compensate for the fixed power of your "little" flash.
Which flash are you using now?
1,346 views & 0 likes for this thread, 8 members have posted to it.
2764 guests, 158 members online
