dezl_dub wrote in post #12507791
Thanks for the advice all.
Here's a first attempt. Didn't really work out as well as I anticipated. Definitely going to try getting into the theater to use the real stage lighting...
Couple of things:
You can't show images here that are not yours. I've converted the images in your first post to links, I suggest you find and give proper credit to them.
And, your first attempt has worked better than you might think.
Your examples show spot lights coming from high and back angles.
You've got the spots working, you've got the back angles, all you need is to get one of them really high, above your subject.
Working in the school theater isn't necessarily going to help, and since they use hot lights, may cause other problems.
The biggest thing your missing, that is in your examples, is smoke.
Get a smoke machine and try it again, you might be surprised at the difference it makes.
However, this is not what I would call traditional portraiture. Your examples are photos from his shows, and serve better as examples of performance photography.
