Thread started 30 May 2011 (Monday) 13:33
Skyport Issue
Playonpics.com
May 30, 2011 13:33 |  #1
Okay i'm having an issue and getting alittle worried.
The skyport Speed Receiver is not working. i charge it (30-45min) and tried unpluggin just to see if the unit work for 1 or 2 shots at home. However once unplug i can't get the unit on. Neither will it power on when its plugged in. Which really it should work since the manual says it can use the unlimited power source.
But to the point seems like the On/OFF power doens't work. Do they act up alot?! Or what? anyways i have put it back on the charger and hoping that Vistek will test one out and send it out today too.
Thoughts comment?
Canon 1D MarkIII | Canon 7D | 70-200mm F/2.8L | 24-70mm F/2.8L| 300mm F/2.8L IS | 50mm f/1.8 | 85mm f/1.8 | 15mm f/2.8 Fisheye | 580EXII Flash | Computrekker | ThinkTank roller and beltsystem | Elinchrom (2) Dlites 4IT Canon Platinum CPS Member
www.playonpics.com (external link)
667 views & 0 likes for this thread.
Skyport Issue
909 guests, 145 members online
