I appreciate you may have been limited as to where you could shoot from and still get everything in shot, but the structure on the left is a little distracting.
Also, just to be slightly picky, the main building looks like it's leaning, which is a result of using a fairly wide angled lens and tilting your camera upwards - it causes the vertical lines to converge towards the centre, making your vertical lines look less vertical. You can correct this to a degree in post processing.
I wonder if it's possible to go back there again, but instead of holding the camera in a horizontal (landscape) oritentation you could rotate it so it's in a vertical (portrait) orientation? That would allow you to get the entire building in shot, but you would also be able to stand a bit closer and not have the roof getting in the frame, nor the wooden structure on the left hand side.
Also you may not have to tilt the camera as far back to get the top of the building in the frame.
