LIke when the subject is dehydrated or not getting enough sleep.
Healing brush isnt working for me. I clone in so lighter skin then healing brush but that is not really great.
sigmapi Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | May 31, 2011 00:45 | #1 LIke when the subject is dehydrated or not getting enough sleep. Don't try to confuse me with the facts, my mind is already made up.
OneEyedJack Senior Member 608 posts Joined May 2007 More info | May 31, 2011 00:53 | #2 can you post the image as an example? I usually just use the patch tool then smooth it out with the clone tool.
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | May 31, 2011 01:02 | #3 Clone works for me. It takes patience, practice, and a light touch. Did you lose Digital Photo Professional (DPP)? Get it here
sigmapi THREAD STARTER Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | May 31, 2011 11:54 | #4 OneEyedJack wrote in post #12507500 can you post the image as an example? I usually just use the patch tool then smooth it out with the clone tool. Thanks for the tip. I dont have a picture at hand but can post one later tonight. cdifoto wrote in post #12507528 Clone works for me. It takes patience, practice, and a light touch. OK I will keep at it. Thanks for the help Don't try to confuse me with the facts, my mind is already made up.
May 31, 2011 12:01 | #5 Thread is relevant to my interests. http://www.avidchick.com
sigmapi THREAD STARTER Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | May 31, 2011 12:56 | #6 nathancarter wrote in post #12509711 Thread is relevant to my interests. My wife has dark circles under her eyes unless she piles on the makeup. They've always been there - even in the photos of her as a toddler, she had bags under her eyes. I'll see if I can get a sample photo up - I'm sure I have some in my Flickr. Sweet! thanks. Don't try to confuse me with the facts, my mind is already made up.
hawkeye60 Goldmember 2,079 posts Likes: 11 Joined Aug 2008 Location: Mesa, Arizona More info | May 31, 2011 12:59 | #7 Try the patch tool, you can use Edit-Fade to lessen the effect if needed. It's a lens not a lense!
emelvee Goldmember 1,871 posts Joined Apr 2009 Location: E-town, Canada More info | Yeah, I use the patch tool as well - lots of practice for me as I have a fatal case of racoon eyes Canon RP | Canon 6D | 70-200 f/2.8 I | 50mm f/1.4 | 16-35mm f/2.8 II | 580EX II x 2
sigmapi THREAD STARTER Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | May 31, 2011 13:35 | #9 Ahhh Ok thanks you two. Exactly the raccoon eye. Don't try to confuse me with the facts, my mind is already made up.
Jun 02, 2011 09:18 | #10 Actually this is easy in Photoshop. CTRL "J" then use the clone tool at 100% opacity and 10 to 20% hardness and using the "good" skin below the circles completely wipe out all traces of the circles. You may need to use the Band Aid tool also. Once the skin is perfect, lower the opacity to about 60% and see if you like it. If it is too much lower it to 50%. If not enough raise it to 70%. Flatten.
tricky500 Senior Member 424 posts Joined Sep 2010 Location: Overland, MO. More info | Jun 02, 2011 09:39 | #11 I make a 50% grey layer and set it to softlight and dodge at 5-8%. If there is significant discoloration I take the eyedropper, sample a flesh tone color that is pleasing, make a new layer and set it to color and use the paint brush set to around 50% opacity. Then I zoom out and adjust opacity to both layers as to keep detail and because I think we all tend to over edit when working at 100% or so. - Paul
angelika76 Junior Member 25 posts Joined Aug 2010 More info | Jun 03, 2011 14:50 | #12 I photograph mainly new moms and most of them have this problem. I don't 100% remove them, because it will look fake. I usually do it in 2 steps.
sigmapi THREAD STARTER Cream of the Crop 11,204 posts Likes: 6 Joined Apr 2010 Location: Los Angeles More info | Jun 03, 2011 17:51 | #13 Thanks! ill try these out. Don't try to confuse me with the facts, my mind is already made up.
k.CHU Goldmember 1,115 posts Joined Mar 2008 Location: City of Angels More info | Jun 04, 2011 11:53 | #14 Use the clone stamp tool in Lighten mode, select a light spot around the dark spot and fill in the dark spot. Kevin Chu Photography
fraiseap Member 131 posts Joined Aug 2009 Location: Birmingham UK More info | Jun 07, 2011 10:52 | #15 k.CHU wrote in post #12535201 Use the clone stamp tool in Lighten mode, select a light spot around the dark spot and fill in the dark spot. Exactly. Set opacity to about 15%, soft brush (20% hardness) lighten mode. Several clicks are needed, move the cursor between clicks and the effect is not noticable. It will keep the texture but put the lighter skin color under the eyes. "If I ever get satisfied, I'll have to stop. It's the frustration that drives you." - Eve Arnold
| Latest registered member is semonsters 1685 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
