Thread started 31 May 2011 (Tuesday) 08:01
7D Sharp or is it me? - 1
Roxie2401
May 31, 2011 08:01 |  #1
I keep thinking my new 7D isn't as sharp as my old 40D with the same lenses. Sent the 7D body and one lens back to Canon (the lens was sharp on the 40D). They said nothing wrong with the AF in the 7D but replaced third group elements in the lens - but the lens was fine on the 40D - go figure.
I'm new to posting photos so these have been resized in DPP to fit the 150kb limit and converted from RAW - no other processing. I never had to "sharpen" on the40D and I don't want to have to on the 7D.
Please ignore the composition, etc. - but I would appreciate comments on sharpness/soft focus. The first image is from the 40D the second from the 7D - same lens.
Fernando
May 31, 2011 08:03 |  #2
The 7D uses a strong AA filter. Sharpening is required.
-F
Fuji convert - Ping me if you have any Fuji gear or legacy glass you're moving.
District_History_Fan
May 31, 2011 08:05 as a reply to  @ Fernando's post |  #3
What lenses are you using?
www.ericmcferrin.smugm​ug.com (external link)
Alex_Venom
May 31, 2011 08:07 |  #4
7D is 18 Megapixels. 40D is 10.
The 7D way higher resolution will evidence any single little flaw in your lenses, and even the smallest camera shake will result in lower per-pixel sharpness.
Besides, a lens working pretty fine on the 40D can be a little off on the 7D and vice-versa due to factory tolerance and calibration. This is why you should probably try to micro-adjust this specific lens to your 7D body.
The anti-aliasing filter on the 7D is also stronger and you should expect to need a little more sharpening on the 7D files to get the detail popped out. ;)
Photography is about GEAR and not talent or practice. Practice won't make you a better photographer. Expensive equipment will. =D
"Nobody can buy a scalpel and become a doctor, but anyone can buy a camera and become a photographer."
Sdiver2489
Joined Sep 2009
May 31, 2011 08:10 |  #5
Tough to see anything from low resolution files. I will say at 300mm you are starting to flirt with too low a SS on a crop camera.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
Roxie2401
May 31, 2011 08:13 |  #6
Fernando wrote in post #12508525 (external link)
-F
Is there any way to avoid having to "post-process" and add sharpening? I thought the 7D would be better "out of the camera?"
Roxie2401
May 31, 2011 08:14 |  #7
Alex_Venom wrote in post #12508542 (external link)
I wondered about the difference between the 10 and 18. It is strange that on my computer screen the 7D shots look "soft" but on a large screen TV at 1080p they look fine.
Roxie2401
May 31, 2011 08:15 |  #8
Sdiver2489 wrote in post #12508558 (external link)
I know - sorry about the poor resolution - is there any way to post on the forum without a web hosting arrangement to get better resolution?
Roxie2401
May 31, 2011 08:17 |  #9
District_History_Fan wrote in post #12508532 (external link)
Two lenses - the EF-S 17-85 and the EF 70-300.
What bugs me is that both lenses appear sharp on the 40D. Never had an issue and there is no micro-adjust on the 40D.
sth_
May 31, 2011 08:24 |  #10
Try resizing the 7D image to the 40D's image dimensions and compare again.
The 7D picture shouldn't be worse than the 40D's in that comparison.
As for the pictures you posted: Too small and too heavily compressed for a real comparison.
Could you upload higher-resolution versions somewhere?
Flickr (external link) :: Gear
Bob_A
Gallery: 48 photos
Joined Jan 2005
May 31, 2011 08:26 |  #11
Roxie2401 wrote in post #12508572 (external link)
All DSLRs require some sharpening to be applied in PP if you shoot Raw. If you shoot jpeg, sharpening is applied in camera (for many cameras even if you have sharpening set to zero or off).
The sharpening is required to overcome the softness introduced by the anti-aliasing (AA) filter which is used to prevent jaggies and moire. Different cameras have different strength AA filters, so the amount of sharpening you need will also be different.
Bob
Sdiver2489
Joined Sep 2009
May 31, 2011 08:28 |  #12
Roxie2401 wrote in post #12508595 (external link)
Keep in mind that the 70-300mm is soft at 300mm. Therefore, a higher resolution sensor isn't going to net necessarily any more detail and therefore looking at it at 1:1 may look "worse". As stated before resizing should look the same.
Gear:
Sdiver2489
Joined Sep 2009
May 31, 2011 08:30 |  #13
Oh an OP, crop a portion of the image you had focused on so that the end crop is about 800x600 or so. That way we can see sharpness on a per pixel level
Gear:
big_g
Gallery: 400 photos
May 31, 2011 08:38 as a reply to  @ Sdiver2489's post |  #14
If you are zooming in to 100% remember that you are looking much closer to the details on the 7D file so it can look worse when it is actually better. You need to print them out the same size or get them to exactly the same size on the screen to be able to compare directly.
If you want the images sharper straight out of the camera then you can increase the sharpening in the picture style menu
Press the picture style button on the back of the camera, then press the Info button. You are then in the menu which allows you to fine tune the .jpeg processing parameters. Just increase the first setting from its standard 3.
Leica M, M Mono, M3, Lux 50 f1.4, SE 18 f3.8, Cron 35 f2, Summarit 35 f2.5,
Hasselblad X1D & 501, Pentax 67ii, Sinar P2
Canon - 5D4, 5DSR,1D4, F1N, A1, 8-15L, 11-24L, Samyang 14, 17-40L, TSE 17L, TSE 24L Mk 2, 24-70L, 50L, 65 mp-e, 100 L IS Macro, 70-200 2.8L IS, 85L, 100-400L, 180 Macro L, 300 2.8 L IS, 500L IS
Flickr Site (external link)
yourdoinitwrong
May 31, 2011 08:48 as a reply to  @ Sdiver2489's post |  #15
As said before the 7D requires sharpening. Here is a picture (not a good one) from the same race after processing. Technically it is a terrible photo but not much I could do from where I was sitting. However, I feel it shows that after some processing the 7D is capable of sharp photos, even with the crappy compression from Photobucket. This was taken with the 24-105. I would have like to have used my 70-200 but I drove one of the Silverados around the track with the military veterans of Afghanistan and Iraq before the race so I had to stick with a lens that would work for that as well.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i708.photobucke​t.com …rong/Indy500201​1-98-1.jpg (external link)
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
15,000 views & 0 likes for this thread
1082 guests, 226 members online
