Thread started 31 May 2011 (Tuesday) 09:53
Replacing 28-135
jcho
Joined May 2011
May 31, 2011 09:53 |  #1
I recently bought a 50D which comes with the 28-135 lens. It hasn't arrived yet, but I think I might want something wider. I currently have a 50 1.8 that I've been using with the older body.
What would be a good lens to get? or should I just keep the 28-135?
tkbslc
May 31, 2011 09:57 |  #2
What is your budget and what do you want to take pictures of?
Without anything specific in mind, I would probably suggest something like an f2.8 standard zoom starting at 17 or 18mm.
Taylor
60D | ELPH 330 | iPhone 5s
jcho
Joined May 2011
May 31, 2011 10:01 |  #3
My budget is around 600-700. I mostly take indoor pictures at a gathering and few landscape here and there but not much.
tkbslc
May 31, 2011 10:23 |  #4
For indoor pictures, I would first make sure you have a nice flash unit. Perhaps a 430EX II or 320EX.
From there, an f2.8 zoom like I mentioned above is still probably the best bet. Perhaps a Tamron 17-50 f2.8 or a SIgma 17-70 f2.8-4 OS? You should be able to get a flash with either of those lenses for $700.
The 28-135 is not a bad lens, it is just not what I would call well suited for indoor use. It is not very bright, nor wide.
Taylor
jcho
Joined May 2011
May 31, 2011 10:37 |  #5
Thanks for the help! I'll look into those lenses and flash
muusers
Joined Sep 2009
May 31, 2011 10:44 |  #6
What about waiting just a while, and using the 28-135 to figure out what you'll need in your next lens?
50D + 17-55 | s100 | flickr (external link)
Ralph ­ III
May 31, 2011 11:14 |  #7
jcho wrote in post #12509235 (external link)
You may want to consider the Yongnuo 468 flash or similar. You can get a brand new one for quite a bit less than the used Canon's. That would keep your funds available for the lens. Go HERE (external link) for reviews/comparisons.
I had the 28-135mm lens and it's a nice walk around lens! You may want to consider just adding a Sigma 17-50 2.8 or Tamron equivalent.
You'd have a pretty nice setup for indoor/outdoor and in lower light conditions. All within your budget, btw.
Good luck
"SOUTHERN and SAVED!"
POTN FEEDBACK...............ITEMS FOR SALE
jcho
Joined May 2011
May 31, 2011 11:15 |  #8
I'll definitely try the lens out first. I just needed a quick backup plan in case it is too long :)
jcho
Joined May 2011
May 31, 2011 11:18 as a reply to  @ Ralph III's post |  #9
Thanks Ralph, I'll look into the Yongnuo flash as well!
So many good advices I feel I'll be a regular on this forum.
819 views & 0 likes for this thread
Replacing 28-135
Latest registered member is Sayan Kumar Mondal
600 guests, 350 members online
