FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 31 May 2011 (Tuesday) 16:36
Bracketing
shedberg
May 31, 2011 16:36 |  #1
Quick question, when doing auto bracketing shots for and HDR photo, is it better to use +/-3 EV or should I stick with +/-2? Should I be using more than just the 3 shots? I see some people are using as many as 11, are these shots done at +/-1 EV?
I tried looking through the tutorial, but that seemed to be more of a processing tutorial as opposed to a shooting tutorial.
6D / 7D / 16-35 II / 35 2.0 IS / 60 macro / 85 1.8 / 135 2 / 100-400 / 430EX II
J-Blake
Great Googley Moogley!
Gallery: 129 photos
Best ofs: 9
May 31, 2011 17:23 |  #2
You're goal is to cover the dynamic range of the shot. If you don't you will either have unrecoverable shadows or blowouts. Obviously, each shot has a dynamic range which will dictate how many shots and at what EV spacing. If you don't have a light meter, you can use the cameras spot meter to determine what the total range is or make sure to cover it by taking enough shots either side. Most on here believe going more than +/- 2 EV's is to much spread between shots and you're leaving something out of the shot. Some are ok going more, and some swear that anything more than +/- 1 EV is to much. One thing is for sure, if you don't take the shot at the time you're not going to be able to go back and get another.
My camera will auto bracket 7 shots, so I almost always shoot 7 shots at +/- 1 EV unless I think this may not be enough for the scene. I have used as much as 14 shots at +/- 1EV before, though these are usually facing into the sun at a sunrise or sunset and there's something in the foreground in shadow.
Jon
So much to learn, so little time.
A few worthy shots (external link)
shedberg
May 31, 2011 17:40 |  #3
Unfortunately my 7D will only bracket 3 shots... I think next time I go out shooting I'll try doing 3 sets, -3 0 +3, -2 +1 +4, -4 -1 +2 and see what kind of results I get.
Thanks for the tips, Jon.
1,102 views & 0 likes for this thread, 2 members have posted to it.
Bracketing
954 guests, 109 members online
