Im thinking of replacing my canon 15-85mm IS with the sigma 17-50mm f2.8 OS has anyone had both lenses and if so which do you prefer?
kingbob734 Senior Member 869 posts Joined Dec 2009 Location: Cheshire, UK More info | May 31, 2011 17:43 | #1 |
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | May 31, 2011 17:45 | #2 Obviously the difference is speed vs range. You are going to have to pick which one you value more. Personally, I would say you have speed covered with the 30 and 50mm primes, so stick with the 15-85. But I am not you, of course. Taylor
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | May 31, 2011 18:56 | #3 No experience with either one. As tkbslc said, you're well covered with 2 fast primes in that range already. I'd keep the 15-85 for it's versatility.
hienz Senior Member 452 posts Likes: 4 Joined Feb 2011 Location: Boston, MA More info | May 31, 2011 19:02 | #4 We nearly have the same lenses! I chose the 15-85 over a constant 2.8 zoom for its range (great for photowalks). You can always use your 430EX II if you absolutely have to use the 15-85 in low light situations. But I usually just use the 30mm, and sometimes the 50mm. stevenhien.com
| Latest registered member is semonsters 982 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
