Thread started 01 Jun 2011 (Wednesday) 16:02
Sports photography: 85mm 1.8 or f2 100mm?
Bclaf
Joined May 2011
Jun 01, 2011 16:02 |  #1
Hello,
I like to do sports photography, and for indoor all I have is the 50mm 1.8.. I'm contemplating between the 85 and 100, I use a t1i, so I have that 1.6x crop effect.. Has anybody used both of these lenses, and have a recommendation or preference? I'd also like to know how each of the lenses focus, the websites say "fast", but I've been having no luck finding whether or not the speed they focus in is significantly different.. I plan on getting a f4, 70-200mm for outdoor sports.
Thanks!
Gripped 6D
Gripped Rebel T1i
Canon 24-105L/85mm f1.8/50mm f1.8
http://www.flickr.com/​photos/bclaf (external link)
IG: bclaf
jantzer
Jun 01, 2011 16:03 |  #2
The 85 1.8 is awesome for sports. One of the faster focusing lenses you will find.
Gear: 5D2, S95, Tamron 28-75, 35L, 135L
rweav72
Jun 01, 2011 16:16 |  #3
85 is great in the corners of the basketball court. It's a little long for under the basket in basketball. Volleyball from the stands would be okay. I found a great sigma 50 1.4 that I used this last season for basketball under the hoop and was very pleased. I used a 7D.
Ron Weaver
Canon 7D, 50D, 1D classic, Sigma 50 1.4, Canon 85 1.8, Tamron 17-50 2.8, 28-75 2.8, Canon 70-200L 2.8 non IS
Nissan 622, Vivitar 383, Yongnuo 560 (3)
Eyal
Joined May 2011
Jun 01, 2011 16:16 |  #4
The 100 doesn't focus as fast as the 85.
I have the 100L which is faster than the non-L, but focus wise its not very fast
5DMarkIII+Grip | Extender 1.4x III / 2x III
16-35mm F/2.8L II | 24-70mm F/2.8L II | 70-200mm F/2.8L IS II
Σ 50mm F/1.4 | 85mm F/1.2L II | 100mm F/2.8L IS Macro | 135mm F/2L | 300mm F/2.8L IS
robertr316
Jun 01, 2011 16:55 as a reply to  @ Eyal's post |  #5
I've used the 85mm 1.8 on a 50D for basketball and it's fast and sharp. Don't think you can go wrong that lens. On a side note, it's a great lens for portraits too.
nightcat
Jun 01, 2011 18:21 |  #6
I like the slightly longer focal length of the 100mm f/2, and its an outstanding portrait lens as well. It all depends where you're shooting from. If your right on the court shooting basketball, the 85mm is long enough. If your further away, the 100mm is a better length. If you're in the stands, a 135mm f/2 is even better.
CountryBoy
"Tired of Goldmember label"
Jun 01, 2011 18:35 |  #7
Bclaf wrote in post #12517601 (external link)
Hello,
Thanks!
Both lens have fast AF , but I found the 100mm a little long . I use the 85mm 1.8 and Sigma 50-150mm2.8 for indoor sports . I like the Sigma better because of the range . But it depends on the lighting .
If you could get a 70-200mm 2.8 instead of the f/4 model you might be able to use it indoors also.
Eyal wrote in post #12517687 (external link)
He's not talking about a 100mm macro !
Hi
plasticmotif
Jun 01, 2011 18:44 |  #8
Whichever focal length suits you, get that. They are very similar.
Mac P.
My Zenfolio (external link) My Photo Blog (external link) My Equipment
https://photography-on-the.net …p?p=14172975#po​st14172975
40dbaby
Jun 01, 2011 19:02 |  #9
I believe "fast" generally refers to the shutter speeds obtainable with larger apertures lenses, not the speed of the AF (although thats important too).
Only an untrained eye can appreciate the sharpness of a lens...
5DII | Zeiss 50 MP | Sigmalux | 85 1.8 | 24-70L | 70-200L II | 100-400L | 580ex II | 430ex II
Bclaf
Joined May 2011
Jun 01, 2011 19:26 |  #10
40dbaby wrote in post #12518558 (external link)
Yes both are important, but most reviews go into a brief summary of how fast AF is.
Gripped 6D
Gripped Rebel T1i
IG: bclaf
Bclaf
Joined May 2011
Jun 01, 2011 19:30 |  #11
rweav72 wrote in post #12517685 (external link)
On average about what ISO do you need at f2.0 to get at least 1/200th shutter speed? When I used my 55-250 f3.5-5.6 in a gym (only lens I had at the time), If i recall correctly I was at 1600 or 3200.. I'd like to have 400- ISO if possible.
Gripped 6D
Gripped Rebel T1i
IG: bclaf
mark2009
Gallery: 12 photos
Jun 01, 2011 19:42 as a reply to  @ Bclaf's post |  #12
I use the 85mm for indoor basketball, at f/2.0 I get a shutter speed of about 1/320 at ISO 1600(max) on my Xsi....I have upgraded to a 50D, and figure I will be at iso2000 to get a shutter of about 1/500, which is really what you need for indoor sports...Your question about getting iso400, indoors you will never get that, or I should say unless the gym has a retractable roof in the day time.
okcomputer
Jun 01, 2011 19:48 |  #13
Bclaf wrote in post #12518686 (external link)
Check out this image comparison:
http://www.flickr.com/​photos/j-pedro/3365877332/ (external link)
If you're at ISO1600-3200 with your 55-250 on the wide end (55), you could probably get away with ISO800-1600 with a 2.8 lens, less with a 1.8 or 2.0.
ISO400 indoors could be pushing it, depending on the light. Obviously a 1.8 or 1.4 is your best bet if you want the fastest...
Canon 5D MKIII + Canon 60D + 16-35 f/4L IS, Σ35 f/1.4 Art, 70-200 f/2.8L IS II
fadetowhite photography (external link) | gear list
Lei514
Jun 01, 2011 20:27 |  #14
go with the 85 1.8. It's perfect and cheap.
stateman
Jun 01, 2011 21:22 as a reply to  @ Lei514's post |  #15
I've had both - 85 can go a bit wider (aperture) and obviously has the shorter focal length. I personally liked having the extra length (insert joke here). But I personally didn't find either difference to be a big deal. 6 of one, half dozen of the other.
Both seemed to AF very fast, no clear winner in that regard. While no complaints really about the 85, my copy of the 100 is great and ended up keeping that one.
6D - 35L II / 24-70 4.0 / 85 1.8 VC / 70-200 2.8 II
5,926 views & 0 likes for this thread
Latest registered member is tushrk
884 guests, 278 members online
