FatCat0 wrote in post #12558136
Short lens would actually make it less-obvious. If you've got a long lens you need to point it right at a person. If you go nice and wide you can give the impression you're focused on something else (and use an outer-AF point).
And a short zoom would draw less attention than a 70-200 or the like.
If you are testing AF on subject material coming or going, having a long lens puts you out of sight a bit more. I would not test how to set up AI servo or AF modes using any other point than the center. Once you can master that AF point, then you can move to the outer ones.
When I play with settings, etc, I am usually at a game located on a aisle, and since everyone has a camera in that environment, it is quite easy to microadjust, or set up AF points and test, etc. with no strange looks.
I have done this activity in a park though as well, with nary an issue.
In summary there is no bad way to practice this, EXCEPT if you learn how to use these features at an actual event where you want to have some keepers.
