Does anyone know if the different lens hoods (ET-86,ET-87,ET-87II) are compatible with an EF 70-200/2.8L USM,as a replacement of it's dedicated ET-83II ?
...mechanically (bayonet-mount),as well as optically?
TIA!
Regards,
J.Doe Member 183 posts Joined Mar 2011 More info | Jun 02, 2011 00:02 | #1 Does anyone know if the different lens hoods (ET-86,ET-87,ET-87II) are compatible with an EF 70-200/2.8L USM,as a replacement of it's dedicated ET-83II ? 60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
Eyal Senior Member 569 posts Joined May 2011 More info | Jun 02, 2011 00:06 | #2 Doesn't the numbers, 86, 87 and 83 refer to hood mounting ring? 5DMarkIII+Grip | Extender 1.4x III / 2x III
TheBurningCrown Goldmember 4,882 posts Likes: 3 Joined Oct 2008 More info | Jun 02, 2011 00:12 | #3 Optically the hoods should all be fine, as they all cover the same focal range. Unfortunately the number on the hood indicates the size of the bayonet mount, so the 86 hood will not fit a lens with an 87mm mount (and vice-versa). -Dave
Jun 02, 2011 00:13 | #4 Eyal wrote in post #12520323 Doesn't the numbers, 86, 87 and 83 refer to hood mounting ring? A 87 won't fit a 83 and so on. Maybe you're talking about the filter thread dimension? 60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
Jun 02, 2011 00:14 | #5 TheBurningCrown wrote in post #12520358 Optically the hoods should all be fine, as they all cover the same focal range. Unfortunately the number on the hood indicates the size of the bayonet mount, so the 86 hood will not fit a lens with an 87mm mount (and vice-versa). OK,I see.Thanks for the reply. 60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
TheBurningCrown Goldmember 4,882 posts Likes: 3 Joined Oct 2008 More info | Jun 02, 2011 00:16 | #6 Happy to help -Dave
Eyal Senior Member 569 posts Joined May 2011 More info | Jun 02, 2011 00:16 | #7 J.Doe wrote in post #12520364 Maybe you're talking about the filter thread dimension? These 70-200 are all 77 mm if I'm not mistaken. Not sure if 83,86 and 87 numbers are only related to different "flavours" (read:generations) of the 70-200,though. Thanks, No no, not talking about the filter size. I know its 77. 5DMarkIII+Grip | Extender 1.4x III / 2x III
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Jun 02, 2011 00:33 | #8 How are lens hoods named? Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Thank you gentlemen for your inputs! 60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
| Latest registered member is MWCarlsson 974 guests, 123 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
