Thread started 02 Jun 2011 (Thursday) 13:41
How to change Kelvin FAST 5d mark ii
calvinnemail
Jun 02, 2011 13:41 |  #1
Hello, does any one know how to change the kelvin temps. on the fly in the 5d mark 2? currently i have to go to menu>white balance>scroll to kelvin, the set the temp then press the set button. is there a faster way like the nikon?
bradboob
Jun 02, 2011 13:49 |  #2
use the top level button above the top LCD to adjust the white balance options, top scroll until you have the K selected, once it's selected you should be able to scroll through the kevin # values without ever needing the LCD screen on. I don't have mine in front of me to confirm, but i'm pretty sure you can do it that way.
6D / Sigma 50 1.4 / 135L / 480EXII
keyframe14
Jun 02, 2011 13:50 |  #3
bradboob wrote in post #12523473 (external link)
^this
Facebook (external link)
www.albert-heisler.com  (external link)
500px (external link)
IG (external link)
Daffodil ­ Hunter
Jun 02, 2011 14:00 |  #4
MMM....you can select K...but from there, I'm not sure how you can change the values.
sbattey
Joined Mar 2011
Jun 02, 2011 14:01 |  #5
Shoot raw?
Canon 7D | Canon 50mm f/1.4 | 430EX II
Blog (external link)
calvinnemail
Jun 02, 2011 14:35 |  #6
can you please confirm this when you get the chance? I was unable to do it this way.
thank you.
*Jayrou
Jun 02, 2011 15:13 as a reply to  @ calvinnemail's post |  #7
That only allows you to set white balance quickly,not change the Kelvin value.
If your 'SET' button is set up to show the quick control screen then that would be the quickest way
I'm presuming your white balance would be set to K, so it would be SET button>highlight White balance>set button >scroll top wheel to change value
if the last control you used in the quick control screen was white balance then it would only be be SET>SET>Scroll
To have the set button open quick control you would go to....
MENU > (C.Fn) > C.Fn IV Operation/Others > SET > 3: Assign SET Button > SET > 5: Quick Control Screen > SET.
James
Flickr  (external link)
Website (external link)
calvinnemail
Jun 02, 2011 15:46 |  #8
*Jayrou wrote in post #12523901 (external link)
this works, yes i would like the values changed.
Thanks for including how to set the set button. this way is fast! unless anyone knows an even faster way..?
srschick
Joined Mar 2011
Jun 02, 2011 16:45 |  #9
sbattey wrote in post #12523533 (external link)
Shoot raw?
this.
WB has no bearing on RAW files...
Current Gear
<--- stands on corner with sign that reads "Will work for L Glass..."
BigBlueDodge
Jun 02, 2011 21:36 |  #10
Register the desired Kelvin as a Custom setting (C1,C2, etc), and when you need that setting, simply switch the dial to C1
David (aka BigBlueDodge)
Gear
phreeky
Jun 02, 2011 22:16 |  #11
And take note (listed in the manual) of what the built-in White Balance settings use for colour temperature. That's a whole bunch of easily selectable options right there.
calvinnemail
Jun 03, 2011 13:09 as a reply to  @ phreeky's post |  #12
Thanks for all the input. I will have plenty of methods to change kelvin.
ben_r_
-POTN's Three legged Support-
Jun 03, 2011 15:52 |  #13
Why even bother with this? Shoot RAW and fix in post. Who wants more things to worry about changing on the fly when shooting?
amfoto1
Jun 03, 2011 17:23 |  #14
A super fast way to access the setting is through the Q screen. To get it to display, simply to press in on the joystick (normally used for AF Point selection... but this time press straight in, instead of tilting it).
That will call up the Q screen. Navigating around the Q screen is also done with the joystick. Navigate to the white balance box, press "set" to enter it or just use the back dial to change to "K", then press "set". This will activate an additional screen where you can use the main dial (by the shutter release button) to scroll and set the color temp you want. Press "set" again, then half press the shutter release button to get out of the Q screen. Done.
You also can access the Q screen from the Info button, whenever the camera is not in an image playback mode (might have to half-press shutter release to get out of review). Otherwise, it's the same.
The Q screen is nice to have whenever shooting in low light, where the top LCD is difficult to see (though you can backlight it pretty easily, too).
One thing... When you set the Kelvin temp manually, you only effect the color temp. This doesn't set the tint. If you set a custom white balance instead, that will set both color temp and tint.
themadman
Jun 03, 2011 18:13 |  #15
Shoot raw?
ben_r_ wrote in post #12530880 (external link)
+1 to both, I don't bother with WB because you can always fix it in post with RAW.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
19,592 views & 0 likes for this thread, 16 members have posted to it.
1064 guests, 102 members online
