Thread started 03 Jun 2011 (Friday) 10:23
The result of a cheapo CPL...
dan.k78
Jun 03, 2011 10:23 |  #1
So I picked up a "multi-coated" CPL (in 62mm) just because it was cheap and I figured if it worked great, if it was crap, I was only out a little bit of $$.
Well it seems that at shorter focal lengths it was okay, but when i got to longer focal lengths it would not focus correctly at all. While looking into why this may be, I ran across this from another thread on this forum:
Yes, depending on the camera, and you have one of the 1.6 crop cameras which all lose AF beyond 5.6, the polarizer can drop your base light level from 3.5 to f7.
I'm not sure I understand what this is saying. I have no problems autofocusing when my aperture is 5.6 or narrower. Anyone got any insight (other than the obvious of this being a piece of junk filter in the first place) as to why focusing seems to be so off at longer focal lengths? Thanks.
Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
mike_d
Jun 03, 2011 10:29 |  #2
Your lens autofocuses when the lens is wide open. If your lens is and f/3.5 maximum and you set it to f/11 for the shot, autfocus will happen while the lens is at f/3.5. It only stops down to f/11 when you fully press the shutter. The polarizer limits light whenever its installed. In this case, it limits the light to the equivalent of f/7, even when the lens itself is wide open. Since your camera can't focus with less light than f/5.6 provides, you lose your autofocus. Its the same deal as installing a 2x TC on and f/5.6 lens where you lose autofocus on all but the 1D series.
dan.k78
Jun 03, 2011 10:34 |  #3
Ahhh...I see. I did not know that. Good to know. So what happens (with no filters of any kind) if you have a lens where the widest aperture is f/6.3 (like at the long end of some zooms); how does the camera achieve focus if it can't open up to f/5.6 or wider?
So is it still possible to manual focus then?
mike_d
Jun 03, 2011 10:36 |  #4
dan.k78 wrote in post #12528963 (external link)
Yep.
Jon
Joined Jun 2004
Jun 03, 2011 10:56 |  #5
mike_d wrote in post #12528926 (external link)
That's actually incorrect. The amount of light transmitted isn't the determining factor. The f/5.6 limitation is directly related to the f/number, not the intensity of the light, as it's because of the baseline available to the AF sensors. Essentially,Canon's AF system (external link) works like a split-image rangefinder; the lens aperture serving as the baseline. Lenses that are close to f/5.6 "lie" to the AF system about their maximum aperture (though still reporting the actual aperture for exposure purposes). But if their exit pupil is too small, the camera/lens combo will struggle to AF anyhow. It's for this reason that "taping" contacts on a teleconverter will let your camera try to AF, but that you'll often experience the lens "hunting" for focus. You'll experience similar problems trying to manually focus a camera with a wedge-type or microprism focusing screen at small apertures; half the focusing area will often "black out", making focusing nearly impossible.
Jon
Cocker Spaniels
cloose
Jun 03, 2011 16:07 |  #6
The zooms that are only 6.3 on the long end report 5.6 to the camera so it will attempt AF. (at least that is my understanding of it)
http://craigloose.com (external link)
tkbslc
Jun 03, 2011 16:13 |  #7
cloose wrote in post #12530964 (external link)
I have noticed that many of the f6.3 lenses don't have the best reputations for AF, though.
Taylor
EOS Rp | iPhone 11 Pro Max
CyberManiaK
Jun 04, 2011 01:03 |  #8
Jon wrote in post #12529097 (external link)
The amount of light transmitted isn't the determining factor.....
Maybe you can explain me.. when using a Manual focus lens with AF Confirmation chip. If I go to lets say F11, the AF sensor never confirms focus.. even if the chip is reporting a F1.4 aperture.. First I said well my adapter is defective, but tried another one with the same results. So I thought the light entering the camera had something to do with the AF sensors. Because if I open the aperture on the lens it will confirm focus. Thanks.
Carlos
60D / 10-20 + 100L + 40/2.8
tkbslc
Jun 04, 2011 01:25 |  #9
but if you are using an f1.4 lens in the dark, you might be getting less light to the sensor than an f11 lens in the bright sun.
Taylor
CyberManiaK
Jun 04, 2011 01:39 |  #10
Well this behaviour it's in bright sun. the scenario: Lens 28mm F2.8 M42 full manual, adapter with AF Confirmation chip. The adapter always report F1.4 to the camera (it shows on the top lcd) if I stop to F11(thats my correct exposure) the focus point on the viewfinder never beeps, litup. So i have to open the aperture until i get the AF confirmation and then stop down. So I think that the light entering DOES matter for AF Sensors, even if the camera "think" is in F1.4..
Carlos
Jon
Joined Jun 2004
Jun 04, 2011 06:57 |  #11
CyberManiaK wrote in post #12533345 (external link)
That's because the actual aperture diameter (RF baseline, see above) is the smaller f/11, not the f/1.4 being reported. The camera doesn't even try to AF if the lens' reported aperture is smaller than the camera's cutoff. It will struggle to focus, but may well fail, if the lens is falsely reporting an acceptable aperture. See also my comments about non-reporting or taped teleconverters failing to AF properly and consistently.
Jon
Cocker Spaniels
Wilt
Jun 04, 2011 08:54 |  #12
CyberManiaK wrote in post #12533462 (external link)
Why are you even trying to focus with the M42 lens stopped down to f/11?...the DOF zone is so wide that you could miss hitting precise focus on the subject by a wide margin. By refusing to show focus confirmation, the camera is making you focus the right way!
CyberManiaK
Jun 04, 2011 13:15 |  #13
Jon wrote in post #12534018 (external link)
Ohh I see thanks
Wilt wrote in post #12534336 (external link)
I focus Wide open, then stop down. And when i'm going to press the shutter, is where I notice that the AF sensors don't beep. And that lead me to think that maybe I move the camera a little, and is not in focus anymore. You get the point?
Carlos
Wilt
Jun 04, 2011 14:53 |  #14
CyberManiaK wrote in post #12535536 (external link)
OK, understand the situation. I certainly wouldn't bother to be concerned about any body movement at f/11 after focusing at f/2.8 unless you walked after focusing :lol:!
elogical
Jun 04, 2011 19:31 |  #15
on the other part of your first question...
Have you tried again in full sunlight just to see? unless the cpl glass is messed up or dirty, there's no way it would stop your lens from focusing. When you say that it wouldn't focus, do you mean that it was hunting back and forth and wouldn't lock or do you mean that it wouldn't try to autofocus? With the aperture issues being discussed above that's a separate issue where the camera won't even try to focus the lens, it won't do anything when you press the focus button
Gear
2,922 views & 0 likes for this thread, 8 members have posted to it.
1062 guests, 104 members online
