Thread started 04 Jun 2011 (Saturday) 11:09
binocular recommendations?
elogical
Jun 04, 2011 11:09 |  #1
Hi,
Sorry if this is a bit off topic and possibly discussed already, but I figured most who are into birding are going to know at least a little about binoculars. I know there's a lot of information elsewhere, especially on birding sites which aren't focused just on photography, but some of the specs are a little overwhelming to me. I'm hoping to just cut to the chase and get some honest opinions on what to look at for budget binoculars and how much I need to spend for decent results.
I'm very new to bird photography but enjoying it and hoping to learn more. I'm now using a 400mm f5.6 on a crop sensor and I was looking for binoculars to also carry along with a higher magnification than the lens has but I don't know how the "mm" on a lens correlates to the "10x", "12x", etc in the binocular specs. I found brief discussion of this searching online and it appears I would need 12x or 13x to match the magnification of the lens, is that about correct? And then my next question would have to be, if I'm only getting about the same magnification, is there even a reason to bother carrying binoculars too or am I just as well off looking through the camera lens?
I'm hoping to spend around $100 or so but with what little I know so far, I'm not sure if I can get away with spending less or if I need to wait and stretch the budget further.
Also, do most of you use spotting scopes or binoculars to sight up the birds first or just start straight-out looking through the camera lens once you find a spot to watch from?
thanks for any insight on the topic and sorry for the convoluted questions... :)
Gear
Methodical
Gallery: 239 photos
Jun 04, 2011 11:21 |  #2
Hello and how are you? I was just in your situation and I just purchased my 2nd pair of Nikon binoculars. My 1st pair are the 8x40 ATB Porro binoculars. They are nice, but a bit heavy (http://www.amazon.com …JK/ref=wms_ohs_​product_T2 (external link)) but in your price range.
My new pair are these (http://www.amazon.com …7&creativeASIN=​B0033PRQB0 (external link)). They are bright, light and I can focus with one hand, something that was difficult to do with the other pair. I hardly notice them around my neck. Btw, I use binoculars to spot birds.
Below is a link that talks about what to look for in binoculars, best budget binoculars etc, etc. Check it out
http://www.birdwatchin​g-bliss.com/best-birding-binoculars.html (external link)
This link is binoculars 101
http://www.birdwatchin​g-bliss.com/bird-watching-binoculars.html (external link)
Gear
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
txcanon
Gallery: 15 photos
Jun 04, 2011 16:49 |  #3
I have the same exact Nikon binoculars as Al posted. I've had them for several years now and are always with me out in the field. They are crisp, light-weight, and waterproof. I also looked at several other pairs such as Audubon and Swarovski but choose the Nikon.
Brad
bradfieldsphotography.​com (external link)
elogical
Jun 04, 2011 17:38 |  #4
Thanks for the links, I have some more reading to do now!
I like the Nikon ones posted too, I'm willing to sacrifice a little on the weight if it means better optics at that price range
Gear
flyingbarron
Gallery: 15 photos
Jun 04, 2011 17:43 |  #5
The advantages of binoculars are weight, size and field of view.
Compared to your camera/lens combo, the binocs are MUCH smaller and easier to handle.
It's an apples and oranges thing.
80D | EF-S 18-135 IS USM | EF-S 10-18 STM IS | EF-S 24 2.8 | EF 50 1.8 STM | 430EX II
Space History & Tech at https://flyingbarron.m​edium.com (external link)
Candor
Gallery: 159 photos
Jun 04, 2011 19:05 |  #6
When I was looking into binoculars the Nikons seemed to be some of the best quality for the price. I purchased one of the Monarchs as well. I don't use it that often but it comes in handy at times but mostly I just use the camera lens to view the bird.
Mike
MikesWildLife (external link)
Naturalist
Adrift on a lonely vast sea
Jun 04, 2011 19:19 |  #7
About 3 years ago I ordered a pair of 8x40 Zhumell from binoculars.com. I never heard of the brand before but they we're well respected and have a 25 year no-fault warranty and darned inexpensive.
I have not regretted the purchase one bit!
5D Mk IV & 7D Mk II
EF 16-35 f/4L EF 50 f/1.8 (Original) EF 24-105 f/4L EF 100 f/2.8L Macro EF 100-400 f/4.5-5.6L[/FONT]
riverdog1
Jun 05, 2011 14:09 as a reply to  @ Naturalist's post |  #8
My wife and I have Swift Audubon's. Waterproof/fogproof etc. We've been very happy
with them and would recommend you compare others to these. I got mine from Adorama.
They are 8.5 x 44 roof prisms. I also shoot with a 400mm 5.6L and like that the magnification
from these binoculars is just slightly more than with the lens.
walternewton
Jun 06, 2011 18:27 |  #9
At or around that price point the Nikon Action Series porro prisms are a good value.
Most birders use binoculars with a magnification between 7X and 10X, go much beyond that and they will be difficult to hold steady enough for a good view...around 8X is good for all around use.
res
Jun 06, 2011 21:33 as a reply to  @ walternewton's post |  #10
I have a set of the nikon atb at 10x. Good glass for the money. I also have a set of pentex compacts that I use for closer viewing. May I give you a suggestion, I would highly recommend if it is possible to visit a decent sporting goods store and ask to try a few of them out. Just as with lenses, the more you spend the cleaner the picture in the binoculars, the better the build, and the better they work in lower light. BUT, just as with camera lenses, everthing with glass is a balance and compromise. I can not afford a 400 2.8 lens but, I was able to obtain a 400 5.6 even though it may not work nearly as well in lower light as the higher expensive lens. It is a compromise I have chosen to work with. My point is, I have had some inexpensive tasco binoculars that did fine in good lighting. BUT, later in the evening, they did poorly seeing in the deep shadows. Their focus was sharp enough that you could make out decent detail. They were not as good as the Nikon but they worked within certain perameters. Since my needs were more for the lower light, I had to find a set that handled the lower light situations. The Nikons were more expensive but they did a better job for what I needed. I also liked the 10x more then the 7 or 8. My needs. By going to the store, trying a few and also looking with consideration of the links you have been given, I am sure you can find a set that will do a nice job for you. Be careful to look at distance and see what kinds of details you can see. Be critical. Look for something of fine detail. You will start to see the difference and you can find the balance that is right for you. Sorry so long but have owned several and still have two models for different situations.
hTr
Jun 08, 2011 21:36 |  #11
To compare Binoculars to Lens I would use 50 MM = X1 for a 400 mm would 400/50 = X8, I use a 10 x 40 Zeiss and have a lifetime warranty!!
gary
hollis_f
Jun 09, 2011 07:20 |  #12
I'd always been a bit doubtfull about paying a lot of money for top-end bins. How could a £1000 pair be so much better than my £250 Bushnells? I'd tried them out on test days and there was a small difference, but nothing to justify the huge difference.
Until I went to Kenya for the first time. On the first evening at Samburu a leopard appeared across the river from the bar I was sitting in. My bins could just show a shadow, slightly darker than the surroundings. Then my neighbour lent me his Zeiss bins and the difference was remarkable, the image was so much brighter.
Now I own a pair of Swarovski 8.5x44 beauties.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Methodical
Gallery: 239 photos
Jun 09, 2011 22:36 |  #13
Has anyone used both the Nikon Monarch 8x and 10x. If so, can you describe the differences?
Hollis, what were the specs on the Bushnells?
Gear
hollis_f
Jun 10, 2011 04:16 |  #14
Methodical wrote in post #12567756 (external link)
Can't remember the model name, just that they were 8x42 roof prism.
DanThoman
Jun 11, 2011 11:24 as a reply to  @ hollis_f's post |  #15
I have a set of nikon action 3 lookout's 10*50 and think they're great. They're 10 or 12 years old and still function fine. Looking at the current prices they must now be manufactured in china, so I can't comment on the quality.
Don't know how shaky you are but I purchased a pair of canon 8*25 IS for my mother a couple of years ago and have been trying to steal them from her ever since. ;);)
http://www.amazon.com …TF8&qid=1307809​193&sr=1-5 (external link)
My next binocs will definitely have IS.
Dan
my gear
10,698 views & 1 like for this thread, 19 members have posted to it and it is followed by 2 members.
510 guests, 125 members online
