Thread started 05 Jun 2011 (Sunday) 22:31
40D problem
mrmerick
Gallery: 18 photos
Jun 05, 2011 22:31 |  #1
Hey everybody, just started having trouble with my 40D this evening. Press shutter, the lens focuses (kit 18-55, 70-200L, nifty fifty), fully charged batteries(tried several), different lighting conditions, and all settings(manual and auto. Some times in landscape it would take, and sometimes in macro it would take, if so, I could fire off a bunch, but once I stopped it would as well. 32K shutter count. Was wondering if this has happened to anyone else. Any help would be very appreciated.
Thanks, Merick
xarqi
Jun 05, 2011 22:56 |  #2
I'm having a bit of trouble understanding what your problem is.
mrmerick wrote in post #12542784 (external link)
OK - there's a problem.
No problem there.
Some times in landscape it would take, and sometimes in macro it would take, if so, I could fire off a bunch,...
No problem there, unless sometimes nothing is happening when you press the shutter button. Typically that will be because focus has not been acquired, and that may be because you are too close or the lighting is too poor.
... but once I stopped it would as well.
Do you mean that once you release the shutter button, the camera continues to take frames? If so, that could be a combination of "drive" setting and auto-bracketing, but you'd only get 2 additional frames. Could also be a sticky shutter release button in combination with one of the multi-frame "drive" modes.
mrmerick
Gallery: 18 photos
Jun 05, 2011 23:07 |  #3
Xarqi, it focuses fine, but won't fire shoot. I've tried all different distances and lighting. If it does shoot, then I can get it to fire off in Av and sometimes Tv, but most of the times it just focuses and doesn't shoot.
Brandon ­ Anderson ­ Photos
Jun 05, 2011 23:16 |  #4
my 30d was doing that also but its due to something "dust" getting stuck under the shutter button and wouldnt allow it to be fully pressed. I sprayed some electrical cleaner around the shutter button and it cleaned it out.
Gear: 2-1D MkIII's | 5D Gripped | 50D Gripped | Rebel 6.3 | 70-200L F2.8 MkI | 17-40 L F4 | 300mm f2.8L | 28-135 3.5/5.6 IS | Nifty Fifty | Canon 15mm 2.8 Fisheye | (2)Norman 400b | 430 ExII | Some Studio Lighting | Go Pro Hero | Go Pro Hero 2
Web Site www.ba-photos.com (external link)
AZGerry
Jun 06, 2011 00:07 as a reply to  @ Brandon Anderson Photos's post |  #5
I had a similar problem. I emailed then called Canon tech support, and they were very helpful. We went through a few processes while we were on the phone, and determined the cause of the issue, which ended up being the ubiquitous "error 99" Had to send it in for a service, but got the camera back fully serviced, cleaned and working flawlessly. Best of luck with the camera.
Gerry
Gerry :cool:
Site: http://picasaweb.googl​e.com/AZWineNut (external link)
xarqi
Jun 06, 2011 00:10 |  #6
Could be that shutter button, but I'd be wary of getting electrical cleaner in there. That stuff can eat plastic, and who knows where it will get to. If you have a "rocket blower" or similar (a bulb type air blower used for shifting dust of lenses, sensors, etc) have a go with that first.
Do you KNOW it is focusing? Do you get the AF points lighting up in the VF, and the confirmation "beep" (if you haven't turned it off like me)? If the lens hunts, but doesn't actually lock on, you may not be able to take the shot.
philwillmedia
Jun 06, 2011 00:16 |  #7
Yep, it sounds like the usual (minor) drama with the XXD series and that there's "grot" of some sort under the shutter button.
Mine does the same thing. It's more annoying than anything.
There's a few threads on here about the 40D and similar issues with other XXD series bodies.
Here's one way of solving it...https://photography-on-the.net/forum/showthre​ad.php?t=907496
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
Southern
Joined Apr 2011
Jun 06, 2011 01:31 |  #8
I think you can use a wireless remote to make sure if the problem is really the shutter button or not... just my 2 cents.
My Flickr (external link)
mrmerick
Gallery: 18 photos
Jun 06, 2011 08:15 as a reply to  @ Southern's post |  #9
Yeah Southern, woke up at 5:30 with that exact thought. Tried blowing, with same result, worked for bit then stops :( frustrating.
mrmerick
Gallery: 18 photos
Jun 06, 2011 19:50 |  #10
Thanks for all the suggestions, believe it was dust under button, just have to push a little harder.
2,014 views & 0 likes for this thread, 6 members have posted to it.
40D problem
889 guests, 118 members online
