Thread started 07 Jun 2011 (Tuesday) 03:27
POLL: "40D or 50D?"
Canon EOS 40D
17
25%
Canon EOS 50D
51
75%
68 voters, 68 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
What is the better semi-pro DSLR camera?
Laizen31
Joined Jun 2011
Jun 07, 2011 03:27 |  #1
I have been thinking of buying a Semi-Pro camera. I was considering Canon 40D or 50D then I would make my Canon 550D my back-up/secondary camera. I'm not really considering 60D because I think that it only has minor differences with the 50D. I hope you guys can help me out. I was planning on upgrading because I felt that I am limited by the 550D's capabilities. THANKS! ^^
Canon 7D | Tamron 28-75mm f2.8 | 18-200mm f3.6-6 | Canon 50mm f1.8 | Nissin Di622 Mark II | Phottix Strato Trigger & Receiver
TijmenDal
Jun 07, 2011 03:35 |  #2
In what way do you feel limited by the 550D? What functions are you missing? The 40/50D isn't terribly much different than the 550D. Apart from the bigger, heavier body I wouldn't say it's worth the upgrade...
The main difference would be that the 40/50D shoots around 6.5fps, the 550D 3.5fps and the 50D has slightly better AF points. The 550D has video too of course.
The main thing is WHAT do you like to shoot? That's what it all comes down to.
Personally, unless you like sports, I'd stay with the 550D and invest in better lenses.
Also, you might wanna check this out:
https://photography-on-the.net/forum/showthre​ad.php?t=826709
Welcome to the forums!
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 07, 2011 03:39 as a reply to  @ TijmenDal's post |  #3
The 60D is quite a bit a more significant change over the 50D than the 50D is over the 40D. In both directions, since there are both additions and removal of features.
You need to widen your scope a bit.
Anders
Laizen31
Joined Jun 2011
Jun 07, 2011 03:53 as a reply to  @ TijmenDal's post |  #4
It's just that I feel i that I need a camera that is more "solid" like I want to step up from the hobbyist level. I want to take photography more seriously. It's not that the 550d has missing functions, it's just that I feel like I want to "grow up" photography-wise. It's more like entering college.. It's not a "need" but you want to go through it because you want to level up your game. hahaha (this reply has been so dramatic) :))
guyzer09
Jun 07, 2011 03:56 |  #5
Maybe you should save the money and invest into some good lenses. A good lens will hold its value and make more of a difference in your photography than a new body will.
Capturing life's moments one one click at a time..
Full GEAR List
E ­ James ­ P
Jun 07, 2011 04:37 |  #6
It would help if you tell what lens you have as well as your budget amount.
Gearflickr (external link)
"Only two things are infinite, the universe and human stupidity, and I’m not sure about the former."
- Albert Einstein (1879-1955) . "Those who cannot remember the past are condemned to repeat it." George Santayana
Yapo
Jun 07, 2011 04:39 as a reply to  @ guyzer09's post |  #7
yeah as others have said here and in other threads...the 550d is a more than capable camera!
It has the same image quality/high iso performance as my 7D and other more recent bodies!
All you're missing is some speed, AF speed, larger viewfinder and some extra button/dials.
what lenses do you currently have?
What do you usually/like to shoot?
Maybe we can recommend you better lenses that will improve your photography more than just a body change...
m4/3: Olympus E-PL2 | Nokton 25 f/0.95
Film: Voigtlander Bessa R3M | Nokton 40 f/1.4 SC
DSLR: Canon 5D MKII | EF 50 f/1.4 | EF 85 f/1.8 | Tokina 11-16 f/2.8 | Rokinon 35 f/1.4 | EF 17-40 f/4L | EF 70-200 f/4L IS | 430EX II
Laizen31
Joined Jun 2011
Jun 07, 2011 06:00 |  #8
I currently have the kit lens of my 550D which is a 18-55mm and a Canon 50mm f1.8 lens. I usually shoot people. Using my camera of course. hahaha
focus.pocus
Jun 07, 2011 06:03 |  #9
how about neither... 7D is the way to go...
I know, right? I'm just sayin'...
District_History_Fan
Jun 07, 2011 07:10 |  #10
Laizen31 wrote in post #12550219 (external link)
After owning the 40D/50D cameras for the past few years, this is an easy question for me to answer. The 40D is a great camera but the 50D is considerably better, despite the internet dribble to the contrary. When I got the 50D the high res LCD blew me away. The lens micro adjust feature is invaluable for a working photog at times. The 40D files always looked great but left me wishing for more detail. The 50D sensor delivered. With the right glass, it is capable of amazing detail. Many folks don't realize it, but Canon really has noise reduction worked out in their Digital Photo Pro. It can do some amazing things. The 50D is every bit as good in regard to noise as the 40D with a 50% resolution boost.
Both cameras offer fast frame rate and decent AF performance.
www.ericmcferrin.smugm​ug.com (external link)
phreeky
Jun 07, 2011 07:11 |  #11
Laizen31 wrote in post #12550520 (external link)
Spend your money on lenses. It will make far far more of a difference than a new body.
EcoRick
Jun 07, 2011 07:14 |  #12
guyzer09 wrote in post #12550276 (external link)
+1. After seeing your lenses, I'd add 1 or 2 quality lenses. You'll see improved/different results from glass far more than you will from a different body.
Gear: Canon 1Ds MkII, 35L, 85L, 135L, 24-105L
SnapFire
Jun 07, 2011 07:39 |  #13
The 50D actually does have some nice upgrades from the 550D. The 50D shoots more frames per second, has a pentaprism instead of the pentamirror resulting in a brighter viewfinder, higher max shutter speed (1/4000 vs 1/8000)... However it is the same image processor and a lower res sensor so IQ will be, at the best, the same. WB options might be a little better on the 50D...?
One area that my 550D falls short is that it doesn't offer a PC Sync port for external flash. I know that I could buy an adapter but it would be nice to have it built in. I don't know if the 50D has one or not.
Either way, I like my 550D but one always longs for the next step up...
SnapFire
Canon 5D
Canon 50D
SaxonIV
Jun 07, 2011 08:24 |  #14
while technically the 550D is better on paper, I will say that I liked shooting with my 40D/1DmkII more simply because it had the quick control dial and had more buttons. It is super easy to change any settings where the 550D was a pain! Always having to press a button for exposure compensation got old. The build quality is obviously better too.
thestone11
Joined May 2011
Jun 07, 2011 09:55 |  #15
You should get some good lens first! Trust me, you will be force to upgrade your body later. Same to me, I bought a 24-70mm f/2.8 L on my 450d, after using it for a while, the 450d doesn't coop with the 24-70mm very good, it is very front heavy since the lens is way heavier than the body. The lack of iso performance on the 450d is another reason for me to upgrade the body as well. I am using the 60d now, the mid range Dslr is way more solid on hand, better control dials, faster AF and image quality is just amazing.
If you like shooting people, should consider picking up a sigma 30mm f/1.4. On a crop camera, this is a great lens, you don't have to walk very far away to capture a little bit more things, unlike the 50mm f/1.8.
If you want a everyday all purpose walk around lens, hands down 24-70mm f/2.8 L.
Canon 5D MK II | Fuji X100 | Canon T2i | Canon 100mm macro f/2.8 | Canon 135L f/2 | Canon 50mm f/1.2 L | 17-40mm f/4 L | 24-70mm f/2.8 L | 70-200mm f/4 L IS USM |Canon 430EX II Flash X2 | Pocketwizard TT5 & TT1
8,112 views & 0 likes for this thread, 27 members have posted to it.
1044 guests, 115 members online
