I go to the beach all the time but have problem with my tripod getting sand in the legs then have a hard time opening them
any ideas on a tripod or would they all be the same?
Fricks Cream of the Crop is, in fact, a title More info | Jun 07, 2011 20:53 | #1 I go to the beach all the time but have problem with my tripod getting sand in the legs then have a hard time opening them
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Jun 07, 2011 20:57 | #2 Gaffer tape the umbrella bags you see at stores over the legs. Or.... I have a $14 tripod I use when it gets to messy. It is not the most stable buy it beats trying to clean mud out of the legs. When it starts to get hard to operate I just toss it and get another.
daveyboi Senior Member 652 posts Likes: 1 Joined Aug 2009 Location: Stockton, CA More info | Jun 07, 2011 23:28 | #3 gitzoocean traveler 5D Mark II // 17-40L SOLD
yogestee "my posts can be a little colourful" More info | Most tripods are alloy. Hose it out/off when you get home,,allow to dry. Jurgen
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Jun 08, 2011 01:03 | #5 I would go with the Gitzo Ocean Traveler as well. Its made for the ocean. It also comes with a stainless steel head that comes apart so you can clean it. You can have a look at it here from B&H for $1,300.00 including free shipping and they also have a $100.00 mail in rebate right now. http://www.bhphotovideo.com …Section_Carbon_Fiber.html Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Sirrith Cream of the Crop More info | Jun 08, 2011 02:44 | #6 I remember seeing a tripod where the extending sections were the opposite to what you see on normal tripods, as in the top section of the legs are the thinner sections, and the lower sections slide over them, not into them. This means that as long as you don't get sand above the lower leg section, there won't be any of it going into the locking mechanism. -Tom
yogestee "my posts can be a little colourful" More info | Jun 08, 2011 08:36 | #7 Sirrith wrote in post #12556330 I remember seeing a tripod where the extending sections were the opposite to what you see on normal tripods, as in the top section of the legs are the thinner sections, and the lower sections slide over them, not into them. This means that as long as you don't get sand above the lower leg section, there won't be any of it going into the locking mechanism. Unfortunately I can't remember what it was called, maybe someone can help out here. Benbo, or to give it its full title Bentbolt. Jurgen
tvphotog Cream of the Crop More info | Jun 08, 2011 08:43 | #8 Look at post #12 in this review. Jay
Jun 08, 2011 09:03 | #9 Berlebach makes wooden tripods that might work well on the beach.
Jun 08, 2011 13:13 | #10 Alot of great ideas here mite have to try a few thanks
CelticTiger Goldmember 1,037 posts Joined Jan 2009 Location: St. Louis, MO More info | Each morning my Wall Street Journal arrives in a waterproof 16" tripod leg condom. A couple of rubber bands and I'm good to go.
Jun 08, 2011 16:01 | #12 Celtic Tiger wrote in post #12558351 Each morning my Wall Street Journal arrives in a waterproof 16" tripod leg condom. A couple of rubber bands and I'm good to go. Sure you can hose a tripod off when you get home; but do you keep the sections extended until you get home? The OPs problem seems to be sand in the leg retraction. That happens the moment you retract a tripod leg with sand stuck to it. +1. I set the height on mine up before I get to the sand, and I leave it alone until I can hose it off. Do the beaches you frequent have showers? Use them to wash it off if you want to fiddle around with adjustments.
Sirrith Cream of the Crop More info | Jun 08, 2011 17:09 | #13 yogestee wrote in post #12557128 Benbo, or to give it its full title Bentbolt. I have a Benbo No 2. One of the toughest tripods ever built. I've had one since the mid 1980s. I used it when shooting 4x5 and medium format. http://www.patersonphotographic.com/benbo-tripods.htm Thats the one -Tom
Jun 08, 2011 17:21 | #14 I use plastic black trash bags. I insert the legs into the bags extended twist the bag around the leg tightly and then gaffer tape them.
Jun 08, 2011 19:22 | #15 MajesticMomentsPhoto wrote in post #12559756 I use plastic black trash bags. I insert the legs into the bags extended twist the bag around the leg tightly and then gaffer tape them. Not the most technologically advanced procedure but it works like a charm... This sounds like a good idea thanks
| Latest registered member is semonsters 1618 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
