Thread started 08 Jun 2011 (Wednesday) 13:29
Not a "what tripod" thread, but a "what tripod head" thread
nigpd
Jun 08, 2011 13:29 |  #1
I would like a nice expensive tripod head to go on top of my Gitzo. I would like it to hold my 7D with max load of the 28-70L f2.8 "brick".
In particular I am looking for the head, once set in a "nearly right" position, to have the facility of ease of fine adjustments in all directions for both landscape and for close ups when using my 100mm L f2.8 IS Macro.
I know macro focussing rails would be the way to go solely for macro, but I am looking to see if there is a head solution that would do both landscape and close up work with fine adjustment capability
What would you recommend?
Thanks in advance
My flickr (external link)
peter_n
Jun 08, 2011 14:03 |  #2
What model Gitzo do you have?
~Peter
nigpd
Jun 08, 2011 14:07 |  #3
peter_n wrote in post #12558651 (external link)
Its a Gitzo GT3541LS Series 3 Systematic Tripod
DavidR
Jun 08, 2011 16:50 |  #4
A geared head. LINK (external link)
I use the Manfrotto 410 head and its excellent for the money.
Sony a9II
hihohito
Jun 08, 2011 16:56 |  #5
I don't know how much the RRS BH55 cost in the UK but I think to buy one good ball head for a first class tripod is worth the money.
Wilt
Jun 08, 2011 17:52 |  #6
The BH-40 or the Markins Q10 are both sized fine for up to 300mm, althought the BH-55 and Q20 physically fit the Gizto 35xx tripod better. The BH-55 is overkill in terms of stability and load carrying if your longest lens is under 300mm. Consider also Arca Z1, or Kirk ballheads or Linhof Profi 1, all are fine products.
gammatnt
Jun 08, 2011 17:55 |  #7
Manfrotto 322RC2 Joystick Head , it is kinda heavy
musso
Gallery: 21 photos
Jun 08, 2011 18:00 |  #8
Take a look at the novoflex line very nice ball heads.
http://www.novoflex.co​m …pport-systems/ball-heads/ (external link)
thank you
joe
RPCrowe
Joined Nov 2005
Jun 08, 2011 18:20 as a reply to  @ musso's post |  #9
You have a top-line tripod...
You have a top-line tripod and I suggest getting a top-line head. This definitely rules out the Manfrotto line. I suggest: Markins, RRS, Arca Swiss, Gitzo or Acratech (There are others - these are just off the top of my head).
There are great advantages to using an Acra Compatible QR system (YOU "CAN" CONVERT A MANFROTTO RC-2 QR TO ARCA COMPATABILITY - BUT WHY NOT GET THE ARCA FROM THE START) is that the plates are basically interchangeable and you can use the great RRS L-bracket. The L-bracket is the tripod head equivalent to sliced bread!
peter_n
Jun 08, 2011 18:36 |  #10
nigpd wrote in post #12558666 (external link)
I use this tripod too. Like a tripod, a ballhead can be a preference choice and it's a good idea to try several before you buy. I tend to look at usability/ergonomics and while I have three different brands of ballhead they all more-or-less work the same way so I don't get confused in the heat of battle. As I stand behind the ballhead the ball locking knob with integrated friction control is on the left, the panning lock knob is facing me at the back of the ballhead, and the drop slot is at the front of the ballhead facing the subject. I hold the camera in my right hand when it's on the head.
I use an Arca-Swiss Z1 on my 3541LS. It's the one copied by most of the rest except for the elliptical ball, which A-S patented. The ball is 54mm in diameter and the ballhead is extremely smooth in use and has handled everything I've thrown at it with ease. Comparatively light in weight it's simple to use and absolutely rock solid. It's the best ballhead I've used and I recommend it.
~Peter
arentol
Jun 08, 2011 23:47 |  #11
If you want fine adjustments then you want a geared head. I use the 410 like DavidR and it is fantastic. Throw a macro rail on top of it and you can dial in absolutely everything about your shot but height, all with ridiculous precision.
If you want a higher-end version you can step up to the 405 or even the 400. There is also an ARCA-Swiss one that is insane, but it is insane in price as well, $1700. In reality though, if you your camera and lens combined don't weigh more than 11 lbs there is no significant benefit to going with anything larger than the 410 because the gears don't get more-precise-enough to justify it for 99% of us.
5D3 | Rokinon 14 f/2.8 | 16-35L II | TS-E 24L | Tamron 24-70 f/2.8 | Tamron 28-75 f/2.8 | Voigtlander 40 f/2.0 | Σ 50 f/1.4 | MP-E 65 | 70-200 2.8L IS II | Σ 85 f/1.4 | Zeiss 100 f/2 | Σ 120-300 f/2.8 OS | 580 EX II | 430 EX II | Fuji X10 | OM-D E-M5 | http://www.mikehjphoto​.com/ (external link)
*****Lenses For Sale (external link)*****
nigpd
Jun 09, 2011 02:26 as a reply to  @ arentol's post |  #12
Thanks for your comments and your recommendations guys, very much appreciated. The comments give me good food for thought, so I have some decision making ahead of me for sure!
Thanks once again
rvdw98
Jun 09, 2011 08:40 |  #13
nigpd wrote in post #12558398 (external link)
You don't often see expensive as a requirement.
Roy
nigpd
Jun 09, 2011 09:03 |  #14
rvdw98 wrote in post #12563051 (external link)
My thinking is, a quality tripod deserves a quality head, and a quality head invariably means an expensive head
rvdw98
Jun 09, 2011 09:12 |  #15
nigpd wrote in post #12563156 (external link)
That's not necessarily true, but I guess that depends on your definitions of quality and expensive. For example, both RRS and Photoclam make quality heads, but RRS can be about double the cost of a comparable Photoclam offering.
Still, most quality heads are also black, but if I was looking for a quality head, I'd ask for that instead of a black head. :D
Roy
8,552 views & 0 likes for this thread, 22 members have posted to it.
973 guests, 109 members online
