Thread started 13 Oct 2005 (Thursday) 22:52
DOF comparison FF v. 1.6 crop
yonni
Gallery: 19 photos
Oct 13, 2005 22:52 |  #1
I am relatively new to this forum and was wondering if anyone had done a comparison of the difference in depth of field of full frame cameras (now that we have the 5D out there along with the mega-bucks pro models) versus the 1.6 crop cameras.
I realize there are sites that give you the number crunching but I was more interested in looking at actual pics, as in the bokeh threads that I found very interesting.
Hopefully this will peak some interest.
Thanks.
John
John
5Dc. 40D 400 5.6, 300 f4 is, 200, 135, 35, 17-40, 24-105, 70-200 f4is Ls
grego
Oct 13, 2005 22:55 |  #2
Here you go: http://www.dpreview.co​m …OS5D/Images/ful​lframe.jpg (external link)
http://www.dpreview.co​m/articles/canoneos5d/ (external link)
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
DocFrankenstein
Joined Apr 2004
Oct 13, 2005 23:04 |  #3
Grego - I think that's comparison of the field of view, not depth of field.
Yonni - given the same field of view on both cameras, to achieve the same depth of field, you will need to stop down by a factor of 1.6 on the full frame camera.
For example, if on 20D you're shooting with an aperture of f/10 then GIVEN THE SAME FIELD OF VIEW, you'll have to shoot at f/16 on the 5D
Does that answer your question?
National Sarcasm Society. Like we need your support.
grego
Oct 13, 2005 23:09 as a reply to  @ DocFrankenstein's post |  #4
Yeah, you are right. Whoops, Sorry. I guess I didn't sleep enough at the library at UCLA. :lol:
yonni
Gallery: 19 photos
Oct 13, 2005 23:14 |  #5
Thanks Doc. It couldn't be simpler.
John
Curtis ­ N
Master Flasher
Oct 14, 2005 06:34 |  #6
I don't know where to find sample shots for a direct comparison, but here's an article that explains the difference. (external link)
Doc's formula holds true IF you're shooting from the same distance and the same field of view is obtained with proportional focal lengths, such as an 80mm lens on a full-frame camera vs. a 50mm lens on a 1.6 camera.
René ­ Damkot
Oct 14, 2005 06:35 |  #7
Here you go: http://www.outbackphot​o.com …hnique/essay07/​essay.html (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Curtis ­ N
Master Flasher
Oct 14, 2005 12:48 |  #8
Thanks, Rene'
The images in that article really tell a story. The difference is more pronounced than I would have guessed.
maderito
Joined Oct 2003
Oct 15, 2005 13:24 as a reply to  @ DocFrankenstein's post |  #9
Doc -
First time I've heard this DOF explanation and it seems to be approximatley true under some conditions but not all. Do you have a source? Did you figure it out from the basic lens equations?
What is true is that the hyperfocal distance for a given FOV is the same if you adjust the aperture so as to correct for the crop factor difference.
Woody Lee
http://pbase.com/mader​ito (external link)
http://maderito.fotki.​com (external link)
DocFrankenstein
Joined Apr 2004
Oct 15, 2005 14:16 |  #10
I did figure it out from the basic equations... but it was eight months ago, and I have successfully forgotten all of them.
Maybe I'll post something about it later.
SkipD
Joined Dec 2002
Oct 15, 2005 14:26 |  #11
Yonni, the answer to your question is somewhat mixed depending on what you are doing with the image. Comparing the two cameras using the same lens can be done two ways. One is to take a photo of the same subject at the same distance and print both to the same size print. The apparent depth of field will be less for the 20D (though I have never calculated how much) because you are taking a smaller image (the size of the sensors is what you need to compare here) and blowing both up to, say, 8 x 12 inches. The 5D starts with a larger image and requires less magnification to arrive at the 8 x 12 print.
On the other hand - if you blow up the SAME PORTION of the subject from both cameras to produce essentially two identical prints (losing much more of the 5D image due to cropping), I believe that you will see essentially identical depth of field. In reality, the 20D image will be sharper because the density of the pixels on the sensor is greater than the 5D's sensor. In other words, you'll have more pixels representing the image cropped from the 20D image than you will for the 5D image. Again, remember that you are taking two shots from the same position, and cropping both cameras' images to produce identical subject material on an identical sized print.
Skip Douglas
maderito
Joined Oct 2003
Oct 24, 2005 08:21 as a reply to  @ DocFrankenstein's post |  #12
Doc,
I am guilty of beating the now expired horse - but I just wanted to follow up on this thread.
I had posted an earlier question asking, in effect, where did you get your facts from. I didn't think it was accurate.
Turns out, what you said is a good approximation, if I am to trust someone who has written one of the best DOF articles I know.
From Paul van Walree
http://www.vanwalree.c​om/optics/dof.html (external link)
Generally, when two formats are compared with the purpose of taking the same picture, the larger format requires a focal length that is R times as large as the lens focal length for the smaller format, where R is the ratio of the format dimensions. The above observation may then be generalized into a rule of thumb:
The smaller format employed at an F-number N yields the same DOF as the larger format at an F-number of R × N. Please note that this rule of thumb is just a rule of thumb, not a mathematically exact relationship. It should only be applied at intermediate and long object distances, because at close range the equivalence breaks down.
"R" can be interpreted as our friend, the crop factor, when field of view is kept constant for the same lens on cameras of differing format.
This rule is, in fact, a reasonable way to think about the differences in DOF given the same field of view with the same lens on cameras with different crop factors.
Doc - thanks for the insight. :)
Woody Lee
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 24, 2005 08:32 |  #13
Awesome bit of info and news to me. :) But makes perfect sense.
Added to the "X-Factor" link page :)
CDS' HOT LINKS
samsen
Feb 07, 2008 01:09 |  #14
Relationship between sensor size and DOF
A friend is killing me by trying to convince me that if you increase the sensor size, say full frame instead of 1.6x APS-c, you will decrease your Depth of Field... My understanding is that DOF is a phenomenon of F/stop and has nothing what so ever to sensor size.
Can any one throw a light in my darkness?!:confused:
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
equetefue
Gallery: 230 photos
Feb 07, 2008 01:12 as a reply to  @ samsen's post |  #15
don't know much about it, but the pics of a full frame have a sort of 3d effect to them, might be something in that sense
http://www.Photo-Galleria.com (external link)
Powered By Canon
EOS R l 5D MkIV l 7D MkII l 5D l 30D IR l 500mm f4 L IS l RF 24-105mm f4 L l 50mm f1.8 l 17-40mm f4 L l 135mm f2 L l 100-400mm f5.6 L L IS II l 100mm f2.8 USM Macro l EF 1.4x III l EF 2.0x III l 580EX II
11,327 views & 0 likes for this thread, 24 members have posted to it.
1467 guests, 137 members online
