CanonYouCan wrote in post #12571105
Which iso setting do you use maximum? Sometimes I see a hell of noise (and lines) with even a 35 1.4L and iso 1600 or 3200.
So Autofocus when moving the camera to the subject is not possible, you manually have to press the button, how can you film everything sharp with no hassle, highest f setting works?
I generally don't go above ISO1600, though it's not that noisy IMO. Computer screens tend make video look much worse than it really is, due to the high resolution and the short distance that you sit from it, on a typical HDTV it will look fine. Try to stay below ISO800 for most purposes, preferably ISO640.
As for focusing, it's all done manually using the focus ring on the lens, and keeping the subject in focus requires practice. Generally people like dSLRs for their ability to throw stuff out of focus, but it's also a nightmare to pull focus at wide apertures, especially without some sort of support rig.
If you want to film everything in focus and without hassle, then you're using the wrong camera, a camcorder with a small sensor, from 1/3" to 2/3" is far easier to use in situations where you can't plan out how you're going to pull focus. The downside is that camcorders comparable to SLRs in video quality are generally very expensive.
