Thread started 13 Jun 2011 (Monday) 04:53
UV vs. Haze
Dr.D
Jun 13, 2011 04:53 |  #1
Is there a difference between a UV filter or a haze filter? I'm finding that I'm using more contrast on in my editing to cut down on haze. I have Hoya UV filters, but keep hearing about haze filters and just wondering if they're the same thing.
6D . Gripped 60D . Gripped XSI . Opteka 6.5 . Canon 10-22 . Canon 18-135 . Canon 50 1.8 MKII . Canon 24-105 f4 L . Canon 70-200 2.8 IS MKII L . Canon 70-300 IS USM . Sigma 150-600 . Canon 100mm Macro . Canon 2X III . 430 EXII . Manfroto 190XPROB . Manfrotto 055XPROB . Black Rapid Sport . Outback 200
https://photography-on-the.net …/showthread.php​?t=1195651
Spaniard
Jun 13, 2011 05:36 |  #2
I'm using B+W UV Haze.
Derrick
Burn Money Project : Canon 5DMKII//24L MKII//50L//Speedlite 580 EXII.
Invertalon
Jun 13, 2011 06:11 |  #3
That did not answer his question at all? ^
I believe there is no difference, and for digital you need neither. If you plan to use a filter for protection, get a clear protection filter. Hoya, B+W, etc... All make them, cheaper then UV's generally.
-Steve
Facebook (external link)
rick_reno
Jun 13, 2011 08:39 |  #4
No difference that I know of between them, I use UV filters from B+W for added protection in bad weather.
RPCrowe
Joined Nov 2005
Jun 13, 2011 09:21 as a reply to  @ rick_reno's post |  #5
When we shot film, UV was a problem because the film was quite sensitive to UV radiation. UV, haze and skylight filters all had their place in film photography for reducing the impact of UV radiation - especially in hazy conditions.
However, our digital sensors are not particularly sensitive to UV and the UV, skylight or haze filters really provide no added benefit except for lens protection; which is another subject that has been addressed in multiple threads.
The best haze cutting filter is the CPL which can often reduce the impact of haze by reducing/eiminating the reflections off the droplets of moisture in the air. However, this reduction/elimination of haze reflections can happen only when the sun is at a certain angle to the camera.
The CPL will also cost you a couple of stops of exposure which may or may not impact your shooting.
PHughes
Gallery: 30 photos
Jun 13, 2011 10:22 |  #6
RPCrowe wrote in post #12584818 (external link)
What he said. There is absolutely no need for a UV or haze filter with digital. Most, if not all, will degrade the image. Some are better than others and there is a wealth of information on this subject on the web. The sensor is more reflective than film as well and the filter is a flat surface, there is an added chance for reflections as a result as compared to using a filter on a film camera.
863 views & 0 likes for this thread
UV vs. Haze
Latest registered member is john4938
652 guests, 250 members online
