I'm getting tired of backing up into walls or falling off ledges trying to frame a shot with my 50mm on a crop. I have the tokina 11-16, but that is useless in most cases because of distortion. I don't want sigma as I don't have time for the buy/return/repeat process to get a good copy of a 30mm.
I think I know the answer since it's better to back off a bit from maximum aperture for sharpness, and I would be using this lens wider a good portion of the time.
I'm a bit worried though; I've already read plenty that says the 1.8 isn't so sharp. If I'm buying the 28mm 1.8, it should be as sharp as the 50mm 1.4 (especially for the money). I'm not worried as much about CA, since CA can be as much user error as lens trait.
The sample archive isn't helping much as far as sharp samples go, but I've only checked 100 posts or so.
So is the 28mm 1.8 worth over double the price of the 2.8? I've read lot's of good about the 35mm, but I can't seem to find it in stock.
