Thread started 15 Jun 2011 (Wednesday) 18:52
Which lens to buy for Safari. Opinions wanted.
memoriesoftomorrow
Joined Nov 2010
Post edited over 8 years ago by memoriesoftomorrow.
Jun 15, 2011 18:52 |  #1
Removed
Peter
Fricks
Cream of the Crop is, in fact, a title
Jun 15, 2011 18:54 |  #2
canon 100-400
suecassidy
Jun 15, 2011 19:01 |  #3
100-400.
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
memoriesoftomorrow
Joined Nov 2010
Jun 15, 2011 19:05 |  #4
Removed
Peter
Fricks
Jun 15, 2011 19:12 |  #5
memoriesoftomorrow wrote in post #12600467 (external link)
Would I need the level of zoom on the 100-400 though given I'd have 224-640 on the 60D?
if your on a safari you can never have to much zoom. A 100-400 would also be a great daytime sports lens
Mark1
Jun 15, 2011 19:52 |  #6
I did a safari in Kenya with only 2 lenses and a 2X about 15 years ago. I brought a 35-105 and a 100-300 and the 2X. Did fine. As mentioned you can ever have too much reach on safari. But the driver I had could get literaly within feet of the animals.
MCAsan
Joined Jun 2010
Jun 15, 2011 20:10 as a reply to  @ Mark1's post |  #7
I think it depend on where in Africa. In East Africa you might get lots of those long savanna shots that can use a 500mm (or larger) with a TC all on a cropped body.
Our experience last year in Kruger SA was that most animals, were definitely within 100-400 range. So we put the rented 500s and our 1.4 TC on our 40Ds. On our 7Ds we had our 100-400s. The vast majority of shots were with the 100-400.
When we go back next summer for 2 weeks, we will again rent the 500s. But rest assured we will be packing the 100-400s and the trusty 24-105s for walkaround. ;)
BrettM82
Jun 15, 2011 21:59 |  #8
The 100-400 is not going to give you any addition reach over the 70-200 + 2x extender combo. At this combo you're going to be at f5.6 the whole way, which is the widest aperture of the 100-400... It really comes down to picture quality. In my opinion, the 100-400 is much better than the 70-200+2x. The pics i've seen coming from the 70-200 Mk II and 2x Mk III combo seem about on par, but i'm not convinced the older combo is up to it.
With that in mind, I've had purchased the 100-400 for my upcoming Kenya safari. I may take my 70-200 as well, for use in lower light at 2.8 if things are close enough.
As others have said, you can never have "too much" zoom on safari. I previously hired a 100-400 and a 600mm for a safari in Kruger. As MCAsan has said, most things were in the 100-400 range, but I also found a LOT of use for the 600, and even took quite a few shots with the 1.4x mounted to it. (all this on a pair of crop 40Ds)
If money is a problem, stick with your 70-200 and extender. If you can spend the $$, i would (and have) get the 100-400.
7D | 40D | 17-55 2.8 IS | 70-200 L 2.8 IS | 100-400 L | 580EX II | 430EX II | 1.4x Extender
memoriesoftomorrow
Joined Nov 2010
Jun 15, 2011 22:38 as a reply to  @ BrettM82's post |  #9
Removed
Peter
BrettM82
Jun 15, 2011 23:14 |  #10
That might not be a bad plan at all actually... If you don't think you're going to have use for the 100-400 after your trip, better to spend the money on something you will use. The other option of course would be to sell the 100-400 when you come back, if you find yourself not using it.
I shoot a bit of motorsport, so that also swayed me into buying the 100-400 as i plan to use it for this purpose once i return.
I have heard only bad things about using the 100-400 with extenders, although I haven't tried this myself. Maybe i'll do some tests with my 1.4x next week, and see if I'm happy enough with the results. I do know that the lens will not autofocus with either extender (unless you do the pin taping trick)
hollis_f
Jun 16, 2011 07:55 |  #11
memoriesoftomorrow wrote in post #12601524 (external link)
It is if I stick the 2x extender on the 60D with a 100-400 i.e. 320-1280
Then you won't be able to get any shots at all! You'll be at 800mm and f11. AF won't work and MF will be near impossible.
You seem to have got the idea that mm is all you need. In fact, very often you'll be easily close enough for 400mm (or 640mm if, as you seem to do, you believe in crop factors) but you'll be hankering after more light.
As others have said - get the 100-400 for use on the 60D and use the 70-200 on the 5D. Here's a selection of images I took in Kenya with a 100-400 a few years ago (external link).
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
memoriesoftomorrow
Joined Nov 2010
Jun 16, 2011 08:51 as a reply to  @ hollis_f's post |  #12
Removed
Peter
scottkinf
Jun 19, 2011 01:46 |  #13
memoriesoftomorrow wrote in post #12600397 (external link)
Okay so I'm off to Kenya later this year to shoot a wedding but also going on a few Safaris at the same time. I am taking a fair bit of kit with me but I'm thinking about getting a bigger zoom. The questions would be do I need it with the kit I already have? and if so which one should I get?
The kit I am taking is which is is relevant to the safari is as follows:
2x 5D MKII
1x 60D
70-200mm f2.8 L IS MKI
135mm f2.0 L
85mm f1.2 L
2x Extender II
The question I guess is the 70-200 with the 2x Extender enough zoom (224-640) on the crop body?
If not, I am considering one of these options (I'd also get the Sigma 2x Extender if I got one of the Sigma options). I've taken a good look through the forum and can't really decide if the zoom is long enough or not. What would I miss by not having something longer?
Canon EF 300mm f/4L IS USM
Canon EF 100-400mm f/4.5-5.6L IS USM
Sigma APO 100-300mm F4 EX DG HSM
Sigma APO 120-400mm F4.5-5.6 DG OS HSM
The price of these is not so relevant but these are all the ones that fall in my budget for the trip.
I don't shoot a huge amount that would use this lens at the moment however I firmly believe in investing well in my glass and it would open up sports work in my off season if I wanted to do it.
Any thoughts would be very welcome.
I just got back from the Serengeti, and my opinion would be to go with the 100-400. With your extenders you should be set for anything.
Scott K.
scottkinf
Jun 19, 2011 01:47 |  #14
The 70 - 200 will likely be your main lens, however there will be occasions where you will need the reach of 300, 400 mm or more, so get the 100-400
Scott K.
dragonsdreams
Aug 10, 2011 02:44 |  #15
The 100-400 no question. You'll use it on 95% of your shots, its sharp so you can crop in PP. In Kenya I found 400mm is a minimum and even if you get in close you'll get some fantastic close ups of lions, cheetahs etc.
Canon 7D Gripped| 450D| 100-400L| 70-200L| 18-135| EF1.4II| Sigma 105 macro| Sigma 12-24| 580EXIII| Benbo| Manfrotto 090|
4,954 views & 0 likes for this thread, 11 members have posted to it.
1050 guests, 105 members online
