That might not have been green screen. Maybe kerosene with flame-retardant clothing.
Do NOT use anything that is combustible. Gasoline and other flammables that give off fumes will explode. Very dangerous.
Kerosene is flammable, but safer.
I think what's really safer (if at all safe) is torch oil (Wal Mart, etc.). It doesn't explode when a flame is put to it. It just burns.
But be careful. Burns on just 30-35% of your body can kill you. The skin is the largest organ, and it's as necessary as your heart.
And keep a running hose next to whatever you do.
I bet if you run torch oil down a dirt ramp and light it, you might get good results. However, the dirt might absorb the oil too quickly.
You can also use resin from Home Depot (used for repairing boats...found in the paint section). It's thick, so you could pour it down the dirt ramp and light it. Just be careful. The can could explode. The resin out in the air won't explode (even though it smells), but the can could, so put it far away.
Also check the legalities of what you're doing. People get charged with arson all the time, and it's a felony.
I did these yesterday using a rock (in the backyard) and clear fingernail polish.
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Thank you.
