Thread started 18 Jun 2011 (Saturday) 12:58
installing ZoomBrowser EX
basic792
Joined Jun 2011
Jun 18, 2011 12:58 |  #1
I am trying to install the ZoomBrowser EX 6.4 on my netbook computer. I have the CD installed on another computer. When I click on Setup.exe on the notebook, I get a message "install.exe could not load Master.ini".
How can I install the ZoomBrowser program on my netbook?
Jon
Joined Jun 2004
Jun 18, 2011 13:56 |  #2
You'll need to connect to an external monitor. Canon's supplied software requires a minimum resolution of 1024x768 pixels; your netbook is 600 pixels high. So the installer won't run and you wouldn't be able to run the apps on it either, except with an external monitor.
Jon
Cocker Spaniels
basic792
Joined Jun 2011
Jun 18, 2011 14:27 as a reply to  @ Jon's post |  #3
Thanks for the reply, but that is not the problem. I can't even load the program. And my computer displays on a large monitor, the resolution set to 11024 x 768!
As I said, the program does not install. I get a message "install.exe could not load Master.ini" and it will not do the install.
What did you do that was different? Did you use an external CD Drive rather than a networked computer's drive?
Jon
Joined Jun 2004
Jun 18, 2011 14:33 |  #4
I've always installed from a connected CD/DVD drive, a flash drive or a downloaded program on the local hard drive. I don't use Zoom Browser once I've added my name to the camera, and DPP is painfully slow on netbooks. I download with Downloader Pro nowadays.
Jon
Cocker Spaniels
basic792
Joined Jun 2011
Jun 19, 2011 15:22 as a reply to  @ Jon's post |  #5
Thanks for the help. I copied the CD onto a memory stick and then it installed ok.
2,022 views & 0 likes for this thread, 2 members have posted to it.
1255 guests, 123 members online
