I recently purchased a used 450D camera and so far I just love it. The kit lens that came with it does not have the image stabilization and I want to upgrade to that. My question is: What is the difference between the 18-55 IS and the 18-55 IS II??
butcherman Senior Member More info | Jun 18, 2011 14:02 | #1 I recently purchased a used 450D camera and so far I just love it. The kit lens that came with it does not have the image stabilization and I want to upgrade to that. My question is: What is the difference between the 18-55 IS and the 18-55 IS II?? Canon 7D, Canon 50mm F1.8 STM, Canon EF-S 55-250mm f/4-5.6 IS STM, Sigma 17-50mm f/2.8 OS HSM , Yongnuo YN560 IV
GregoryF Goldmember 2,336 posts Likes: 13 Joined Jul 2010 Location: Bella Vista, AR More info | Jun 18, 2011 14:17 | #2 The only difference is cosmetic, the optics are the same. Get which ever one that you can find the best deal on. Used ones are allway's poping up here and on Fred Miranda. 6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!
Jun 18, 2011 15:30 | #3 The 450 originally came with the IS version...or so I thought...how did you get stuck with a non-IS? My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
Jun 18, 2011 15:47 | #4 Thats what came with the camera. I was not knowledgeable enough at the time to know whether it should come with an IS one or not. Canon 7D, Canon 50mm F1.8 STM, Canon EF-S 55-250mm f/4-5.6 IS STM, Sigma 17-50mm f/2.8 OS HSM , Yongnuo YN560 IV
silverpilot03 Member 123 posts Joined Jan 2009 More info | Jun 18, 2011 16:06 | #5 butcherman wrote in post #12615927 I recently purchased a used 450D camera and so far I just love it. The kit lens that came with it does not have the image stabilization and I want to upgrade to that. My question is: What is the difference between the 18-55 IS and the 18-55 IS II??
way too much Canon stuff for an amateur
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Jun 18, 2011 16:38 | #6 butcherman wrote in post #12616292 Thats what came with the camera. I was not knowledgeable enough at the time to know whether it should come with an IS one or not. where did you buy it? I thought they always came with the 18-55IS
Jun 18, 2011 17:27 | #7 I believe I've read that the 1st IS version is better built...but I can't confirm this... My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
Jun 18, 2011 17:29 | #8 butcherman wrote in post #12616292 Thats what came with the camera. I was not knowledgeable enough at the time to know whether it should come with an IS one or not. Check your box...check your receipt to see if you received what in fact you bought.. My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
gonzogolf dumb remark memorialized More info | Jun 18, 2011 17:29 | #9 GregoryF wrote in post #12615979 The only difference is cosmetic, the optics are the same. Get which ever one that you can find the best deal on. Used ones are allway's poping up here and on Fred Miranda. I dont think this is accurate. When the IS version of the lens came out there were tests that indicated that it was sharper. The original non IS lens was a bit of a turkey.
jack880 Goldmember More info | Jun 18, 2011 17:58 | #10 There was a non is which was supposed to be a bit crap,then an IS which is supposedly much sharper than the non IS, then an IS mk2. So 3 lenses altogether. Not sure what the difference is between the IS and IS mk2. https://www.flickr.com/photos/jackhenriques/
GregoryF Goldmember 2,336 posts Likes: 13 Joined Jul 2010 Location: Bella Vista, AR More info | Jun 18, 2011 18:21 | #11 gonzogolf wrote in post #12616691 I dont think this is accurate. When the IS version of the lens came out there were tests that indicated that it was sharper. The original non IS lens was a bit of a turkey. I was comparing the 2 is versions, not the non is version which is inferior. 6D, 5D, 7Dii, Eos R and too many lenses, flashes and aux. gear to list!
MikeFairbanks Cream of the Crop 6,428 posts Likes: 2 Joined Jun 2009 More info | Jun 18, 2011 18:28 | #12 The IS makes a difference. At 55mm on a crop camera it's actually telephoto, which means it will magnify the shaking. Thank you.
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | ckckevin wrote in post #12616580 The Mark II of 18-55mm is the IS version. Mark 1 is the non-IS version. So, 18-55mm IS is the same as 18-55mm IS II. No part of this is correct.
ckckevin Goldmember 1,439 posts Likes: 1 Joined Jul 2009 Location: Bay Area More info | Jun 19, 2011 04:34 | #14 opps, my bad Kevin life= learning
Jun 19, 2011 04:37 | #15 I bought the camera off Ebay. Did not know anything about IS or non IS at the time. This is my first DSLR and I have a lot of learning to do. Canon 7D, Canon 50mm F1.8 STM, Canon EF-S 55-250mm f/4-5.6 IS STM, Sigma 17-50mm f/2.8 OS HSM , Yongnuo YN560 IV
| Latest registered member is Marcsaa 506 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
