http://www.youtube.com/watch?v=wbpd3ntLi3E![]()
This time i increase more contrast ... i found it really easy to change sky color too .. so far so good ... i love cinestyle
jakele_x Member 187 posts Likes: 1 Joined Dec 2010 More info | Jun 18, 2011 17:14 | #1 http://www.youtube.com/watch?v=wbpd3ntLi3E 5D Mrk II | T2i gripped | EF-s 18-55mm f/3.5-5.5 IS | EF 85mm f/1.8 | EF 70-200mm f/4 L
weareallhypocrites Member 154 posts Likes: 1 Joined Jun 2011 Location: Seattle, WA More info | Jun 20, 2011 16:45 | #2 much better contrast this time
Jun 21, 2011 02:41 | #3 nice work here mate. some flippin footage. sorry can i ask a noob question? when you're editing how do you slow the footage down and then speed it up in the same clip. i have only just started using FCP. do u slow from 60p to 24p in cinema tools and then speed up the parts of the clip u want in fcp? ---Adam--- Facebook
bpaulette Senior Member More info | Jun 21, 2011 10:05 | #4 This is a great example of one of the downsides of cinestyle, in the way it chops out the bottom 16 levels -which can create banding in areas that would normally be slight gradients - your sky shows very noticeable banding (which, most likely wouldn't be present if the footage had all 256 levels intact). - BP -
Jun 21, 2011 17:49 | #5 regnis wrote in post #12630471 nice work here mate. some flippin footage. sorry can i ask a noob question? when you're editing how do you slow the footage down and then speed it up in the same clip. i have only just started using FCP. do u slow from 60p to 24p in cinema tools and then speed up the parts of the clip u want in fcp? you made 2 copies of ur footages ... one you use cinema tool to slow it down keep the other ... then connect it in real clip ... that's it 5D Mrk II | T2i gripped | EF-s 18-55mm f/3.5-5.5 IS | EF 85mm f/1.8 | EF 70-200mm f/4 L
Jun 22, 2011 00:28 | #6 ok... so how do i put them together without having the obvious cut in the middle? ---Adam--- Facebook
Jun 22, 2011 00:40 | #7 don't worry.. sorry i think this noob has worked it out ---Adam--- Facebook
gibsonla Goldmember 1,009 posts Likes: 1 Joined Oct 2009 More info | Jun 22, 2011 02:04 | #8 bpaulette wrote in post #12631858 This is a great example of one of the downsides of cinestyle, in the way it chops out the bottom 16 levels -which can create banding in areas that would normally be slight gradients - your sky shows very noticeable banding (which, most likely wouldn't be present if the footage had all 256 levels intact). Personally, the more I try Cinestyle, the less I like it due to issues like this. Other than that, fun stuff. You're out there shooting, testing, learning - good on ya! Just curious, what picture style do you use? I tried Cinestyle, now I lean more towards just shooting in neutral with contrast at -4, saturation at -1, sharpness at 0 Michael L. Solomon
bpaulette Senior Member More info | Jun 22, 2011 11:33 | #9 gibsonla wrote in post #12637180 Just curious, what picture style do you use? I tried Cinestyle, now I lean more towards just shooting in neutral with contrast at -4, saturation at -1, sharpness at 0 I shoot very similar to you for the most part, neutral, contrast -3, sat -2, sharpness 0. In certain circumstances I use Marvel, but for the most part I try to get it as close in camera as possible. Had high hopes for Cinestyle, but find the banding and noise that suddenly appear in grading are too much for my tastes. But that's just me - BP -
| Latest registered member is Thunderstream 1859 guests, 101 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
