Does anyone use this hack?
Are there any issues using this?
is it easy to do?
I have been doing searches on it and not sure if I should use it on my sx30is.
I want to be able to capture raw images.
Jun 19, 2011 22:40 | #1 Does anyone use this hack? Nikon D850 and a bunch of stuff, I have learned a lot here when I was shooting Canon, staying to keep learning..."Every time I set up I learn something new".
eyalg Senior Member 583 posts Joined May 2008 More info | Jun 20, 2011 01:19 | #2 From what I've heard, CHDK works fine with the SX30, and indeed allows RAW capture. My Digital Camera Guide - www.eyalg.com
thejimmy Goldmember 1,426 posts Likes: 33 Joined Dec 2009 Location: west coast of Florida More info | Jun 20, 2011 17:19 | #3 mswobo wrote in post #12623143 Does anyone use this hack? Are there any issues using this? is it easy to do? I have been doing searches on it and not sure if I should use it on my sx30is. I want to be able to capture raw images. I use it on my A540 and G11.
c2thew Goldmember 3,929 posts Likes: 4 Joined Aug 2008 Location: Not enough minerals. More info | Jun 20, 2011 17:56 | #4 Load up CHDK onto your sd card then add the scripts under the "user-written scripts" section and watch as your camera becomes that much more powerful. CHDK is a wonderful application/mod Flickr
bklynwriter Hatchling 6 posts Joined Jun 2011 More info | Jun 23, 2011 15:49 | #5 I have not been able to gt CHDK to work, and I am not sure why. I will troubleshoot (again) this evening and check youtube.
hnikesch Goldmember More info | Jun 23, 2011 16:07 | #6 I use CHDK on both my SD 900and SD990 Great stuff, lots of additions to the Canon OP. I don't use raw often but when I do I use DNG option DNG is supported by PSE 9 where CHDK raw is not bklynwriter wrote in post #12646347 I have not been able to gt CHDK to work, and I am not sure why. I will troubleshoot (again) this evening and check youtube. bklynwriter there are several things that can cause loading problems, card size and card format, easier with a max 4mp card and must be formated fat16. if you follow the instructions to the letter it will work see link below Hans
sharayahw Mostly Lurking 10 posts Joined Apr 2011 More info | Jun 23, 2011 17:24 | #7 1. yes, I use it on my SX30 IS
c2thew Goldmember 3,929 posts Likes: 4 Joined Aug 2008 Location: Not enough minerals. More info | Jun 23, 2011 17:27 | #8 Format your SDHC card first to fat 16 or 32, i forget. Flickr
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jun 23, 2011 17:28 | #9 FAT16, IIRC. Most cards of over 2 GB come FAT32, but can be forced into FAT16 format at the Windows Command Line. Jon
bklynwriter Hatchling 6 posts Joined Jun 2011 More info | Jun 23, 2011 19:53 | #10 i'm formatting FAT16 right now. finally figured out that my firmware is 1.00M...so hopefully I can get it working.
bklynwriter Hatchling 6 posts Joined Jun 2011 More info | Does the fact that I'm using a 4GB card make any difference? How do I access the CHDK menu after I put the card into the camera?
| Latest registered member is Thunderstream 1255 guests, 123 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
