Thread started 20 Jun 2011 (Monday) 21:57
M12 - First attempt
legoman_iac
Jun 20, 2011 21:57 |  #1
Hey guys ... finally got back out under the stars last night and tried my hand at M12. Still struggling to polar align as I am boxed in quite well in my backyard with a limited view.
This is 7min 15sec (29 exposures @ 15sec) with equal parts light to dark subs. Was guiding (badly) and didn't want to push it. Though did get a couple of subs at 1min at the end which I'll play with tonight and see if it adds to the image.
Keen to hear feedback and processing tips ... after Deep Sky Stacker did its thing, took this into Photoshop and tried the Levels/Curves 1,2,3 technique, though suspect that is better for nebulae than globs?! Any other ideas?
Orion ED80T CF + HEQ5 + Canon 50D (prime focus) + Thick Jacket & Beanie
Regards,
Daniel
2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
Celestron
Jun 20, 2011 22:42 |  #2
I see a very nice GC ! It does need to be edited in PS tho maybe working with the Color balance and variations . Just watch the BP closely cause your close to clipping it anyway . If you can add more data to this or increase your exposure time this can come out looking even better . But as i said this is a very nice GC now ! Also you might increase the Resolution to 150 which will slightly enlarge the image without adding noise .
legoman_iac
Jun 21, 2011 17:40 |  #3
Hey Ron, thanks for the comments. Never sure how to adjust the colour balance with astopics, I'm wanting to keep it as true to life but then want it to be as clear and contrasy as possible and my creative side takes over. Was quite careful with the Black Point, and keep and eye dropper on the darkest region and brightest region ... how black do you go? I know to stay clear of RGB: 000 ... or do you try to keep the faintest detail?
Had a look through my unused subs and found only one 1min sub to add to the mix, makes such a difference! In DSS I've re-stacked my 15sec subs and added the 1min, as well as enabled 3x drizzle, below is a comparison between both 16bit TIFs (straight out of DSS):
Then here is my new PSD'd, version 2 - now total exposure: 8 min 30 sec.
Though to me this looks like I've gone too far with the BP, however getting much more light through.
- Daniel
SteveInNZ
Jun 21, 2011 18:27 |  #4
The last one looks good.
That's your first DSO posting, isn't it ? Way to go.
Steve.
"Treat every photon with respect" - David Malin.
Celestron
Jun 21, 2011 19:37 |  #5
Read this section that Jerry Lodriguss (external link) has on his website . With help of better pros than me i usually try to use this as a guideline . SteveInNZ is good at this also so take heed what he may advise . Another here also is NightHound (Steve) . Hes' also very good .
SteveInNZ
Jun 21, 2011 19:54 |  #6
You must have me confused with someone else. I'm nowhere near the league of Nighthound, Cat, etc.
Celestron
Jun 21, 2011 20:57 |  #7
SteveInNZ wrote in post #12635335 (external link)
Now how am i suppose to take this Steve when i've seen your pictures ??
https://photography-on-the.net/forum/showthre​ad.php?t=954461
SteveInNZ
Jun 21, 2011 21:29 |  #8
I rest my case. :)
legoman_iac
Jun 21, 2011 23:01 |  #9
Hahaha ... hey!!! Didn't mean to cause an argument!
1. Celestron, thanks for the link will check it out.
2. Steve, thanks for praise ... think it is my first DSO on here.
3. Steve, you picures rock! Stop being so modest ... makes us mere mortals feel bad, haha.
Now for me to get back out there and capture longer subs.
Thanks again all for the support. THough was hoping for some harsher constructive criticism??
megrac
Jun 22, 2011 00:16 |  #10
Cool cluster shot. I'm going to have to have a go at this one, maby after Omega centauri though.
60D | Canon 15-85 | Canon 200mm f/2.8L II | Canon 400mm f/5.6L | 580EX II. And a heap of Astrophotography gear.
legoman_iac
Jun 22, 2011 01:52 |  #11
Thanks! I wish I could see omega centauri from my yard :(
megrac
Jun 22, 2011 03:17 |  #12
I'm doing Omega centauri right now, its looking good. There is lots of things you guys can see that we down here cant.
4,801 views & 0 likes for this thread, 4 members have posted to it.
M12 - First attempt
1059 guests, 115 members online
