Thread started 21 Jun 2011 (Tuesday) 11:17
Migration assistant problems
hania
Jun 21, 2011 11:17 |  #1
I have an imac and macbook pro.
Tried using the Migration assistant (moving files from macbook to imac) but ran into problems.
Connected them with firewire 800 and followed instructions: but macbook would not restart - just had firewire symbol on.
Then tried using a network - managed to get both connected , but was not given option which files to transfer - transfer seemed top start & finish & when I looked on my imac I had an empty "home' folder.
Tried a few more times and both hung - had to use force quit on both.
Now it appears that I may have fried the 800 socket on my imac as my external drives are not recognised when plugged in (but are seen when in firewire 400).
Is this possible or a coincidence?
Tony-S
Jun 21, 2011 11:49 |  #2
Try repairing Disk Permissions and if that doesn't work, boot from your Installer DVD on the MB and then do Disk Repair (these are with Disk Utility in Applications/Utilities​). Then, boot the MB while holding the T key and after the FW icon appears on the screen THEN connect it to your iMac.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
hania
Jun 21, 2011 12:10 |  #3
Tony-S wrote in post #12632466 (external link)
Shall try that - all the info I could find said connect then boot the MB!
ben_r_
-POTN's Three legged Support-
Jun 23, 2011 12:45 |  #4
Not sure about your problem, but I opted to skip the Migration Assistant and just used an external hard drive as a Time Machine drive and then restored the backup onto the new computer using Time Machine again. Worked perfectly.
MaxxuM
Jun 23, 2011 14:03 |  #5
Also might want to check hard drive for errors.
Hen3Ry
Jun 23, 2011 14:10 |  #6
hania wrote in post #12632290 (external link)
When it did this, did you look on the imac to see if it was mounted on the desktop or available in a finder window?
You may want reset the PRAM on the MacBook.
Je n'avais pas besoin de cette hypothèse-là.
776 views & 0 likes for this thread
Latest registered member is Arti
1035 guests, 316 members online
