Thread started 21 Jun 2011 (Tuesday) 13:47
16-35mm f2.8 - v - 17-40mm f4
phil1664
Jun 21, 2011 13:47 |  #1
Can anyone offer an opinion on the main difference bwtween these 2 lenses (apart from the obvious f-stop!) Clearly one is around double the price of the other no matter where you buy it so can onyone say that the 16-35 is worth the extra money? If it is, I'll buy if, but if the difference is minimal, then I can't see how the extra money will benefit.
Having said all that, I'm willing to pay for quality and am willing to chop in my Sigma 10-20mm f3.5-4.5 as well as my Sigma 70-200mm f2.8 to help fund this lens.
Any advice appreciated.
Phil
www.minus9photography.​co.uk (external link)
Feedback always welcome!
bufferbure1
Jun 21, 2011 14:01 |  #2
Depends what you use it for. Do you have a FF?
For landscape, you will be fine with 17-40 or zeiss 21mm f 2.8
If you need AF and f2.8, go for 16-35
"I collect pictures, not gears..."
Lenscode:1635.1785.50f​18.100Macro.70200F4IS.​580EX.30D.5D2
Mikail
Joined May 2011
Jun 21, 2011 14:11 |  #3
phil1664 wrote in post #12633195 (external link)
Something tells me you don't have full frame. :rolleyes:
5Dc + 17-40L f/4 + 50 f/1.8 + 70-200L f/4 IS
phil1664
Jun 21, 2011 18:43 |  #4
Nope, I don't have full frame at the moment, got a 1d Mk2 at the moment so 1.3 crop, but looking to aquire either a 5d Mk2 or a 1ds Mk3, depends on the costs ets.
As for use, mainly weddings, portraits & commercial photography, so I need the AF for he weddings. I've got a 24-70 f2.8L and 70-200 f2.8L IS but Im missing the at the wide end. The Sigma was OK but is not a top end lens, the light is not equal across the image at all and was a good servant over the last 5 years, but time to go I'm afraid!
I'm tempted to go the extra mile and pay for the 16-35 as I may have to shoot wide open on occasions, but still can't decide if it's worth the money or just ramp up the ISO for a couple of shots!!
LowriderS10
Jun 21, 2011 18:54 |  #5
Are you talking about the 16-35L or the 16-35L II. There's a big difference between those two.
If you're talking about the original, I wouldn't bother. I was in the same dilemma myself. I couldn't afford a 16-35L II and all the samples and reviews I saw of the 16-35L vs. 17-40L pointed me toward buying the 17-40L. I was very happy with it for a while, but then I saved up some money and decided to move halfway around the world and travel a lot, and wanted that extra mm on the wide end and the quickness of the 2.8, so I sold the 17-40L and picked up the 16-35L II, which I am very happy with.
For weddings and stuff I'd definitely go with the 16-35L II, the extra wideness of that lens coupled with the extra stop would be very helpful for indoor low light stuff. However, if you can't afford that, I'd go with the 17-40L + a 1.8/2.8 prime of some sorts over the 16-35L.
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
thestone11
Joined May 2011
Jun 21, 2011 18:54 |  #6
phil1664 wrote in post #12634959 (external link)
If you already have the 24-70mm, I wouldn't go for either the 16-35 nor the 17-40. On a crop body, they are not wide enough IMO. I rather go with the 10-20mm or tokina 11-16mm. The Tokina will be my pick and it has f/2.8 too, great lens for the money~!
Canon 5D MK II | Fuji X100 | Canon T2i | Canon 100mm macro f/2.8 | Canon 135L f/2 | Canon 50mm f/1.2 L | 17-40mm f/4 L | 24-70mm f/2.8 L | 70-200mm f/4 L IS USM |Canon 430EX II Flash X2 | Pocketwizard TT5 & TT1
Zerimar
Jun 21, 2011 18:56 as a reply to  @ LowriderS10's post |  #7
One does 2.8 the other does f4.
The f4 can't do 2.8.
The extra stop can really be a life saver.
If you do not need to shoot at f2.8 often then the 17-40 f4 is better for your needs.
Rick Rose - Add me! (external link) Photography Los Angeles California Hasselblad H2 x2 + Phase One IQ150 | Canon 5D MkII | RRS TVC-34L BH-55
HC 35 f3.5 | HC 100 f2.2 | HC 120 f4 Macro |HC 50-110 f3.5-4.5 | 85 f1.2 MkII L | 100 f2.8 Macro | 16-35 f2.8L II | 24-70 f2.8L II | Profoto + Mola
Gear List | Website (external link) | Facebook (external link) | Flickr (external link)
nicksan
Man I Like to Fart
Jun 21, 2011 19:12 |  #8
Simple decision. You either need f2.8 or not. That's what it boils down to. We can't make up your mind for you! :)
nikesupremedunk
Jun 21, 2011 19:56 |  #9
not so simple as you don't always know if you "need" the 2.8 until you use the lens .i'd take the 16-35 ii but might end up getting the 17-40 since it costs 1/2 less and i already have 77mm filters. 82mm is too big.
| Andrew | 5D Mark II | EOS-M | Canon 17-40mm f 4 L | Canon 35mm f 1.4 L | Canon 100mm f 2.8 L Macro | Canon 70-200mm f 4 L IS | Canon EF-M 22mm f 2.0 | Speedlite 430EX II|
nicksan
Man I Like to Fart
Jun 21, 2011 20:36 |  #10
nikesupremedunk wrote in post #12635342 (external link)
You don't?
I usually know whether I "need" the f2.8 before I even use the lens.
Of course, it depends on usage. OP mentioned weddings. Indoors? Outdoors? With or without flash, etc.
crazeazn
Jun 21, 2011 21:24 |  #11
ifs its version 1 then get the 17-40, version II is better.
John H.
some bodies, some lenses
nikesupremedunk
Jun 21, 2011 21:29 |  #12
nicksan wrote in post #12635541 (external link)
You don't?
not necessarily. i never thought i'd need 2.8 on a UWA but still went with the tokina for some reason. after using it i was glad i got a 2.8 even on a UWA and not a slow sigma 10-20.
i'd try to get the 16-35 but 17-40 is a pretty good deal that's hard to beat.
sskrnguy
Joined Jun 2011
Jun 21, 2011 21:44 |  #13
question.. i also have a 17-40 f4 .. planning to upgrade to 16-35 2.8 . is the 2nd version that much better than the first?
LowriderS10 wrote in post #12635013 (external link)
nicksan
Man I Like to Fart
Jun 21, 2011 21:56 |  #14
sskrnguy wrote in post #12635936 (external link)
2nd version is better in the corners and more flare resistant. Of course it also has the blasted 82mm filter size!
macroshooter1970
Jun 21, 2011 22:00 |  #15
http://www.the-digital-picture.com ….8-L-USM-Lens-Review.aspx (external link)
http://www.the-digital-picture.com …L-II-USM-Lens-Review.aspx (external link)
5,463 views & 0 likes for this thread, 12 members have posted to it.
1045 guests, 170 members online
