i have a 430ex flash that wont hss in AV mode
switch it to TV, MAN, it works just fine
the metering says it is correct but it comes way blown out.
shooting with a 7D
matt99017d Member 187 posts Joined Nov 2010 Location: Medford OR More info | Jun 21, 2011 15:34 | #1 i have a 430ex flash that wont hss in AV mode 70-200 F4 L sold 10-22 sold
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Jun 21, 2011 15:39 | #2 Av and ETTL are usually a bad combination, HSS or not. -- Ken
Jun 21, 2011 15:43 | #3 krb wrote in post #12633881 Av and ETTL are usually a bad combination, HSS or not. Take a look at the shots and see what shutter speeds the camera is selecting. If the camera is choosing something faster than 1/250 then HSS is working. Also, there's a custom function that will lock the shutter speed when you are in Av with a flash attached. Check that CF and make sure you are not forcing the shutter speed to something slower. it was in the CF. 70-200 F4 L sold 10-22 sold
apersson850 Obviously it's a good thing More info | Use M mode when using flash. It will make your life easier. Anders
| Latest registered member is ANebinger 1075 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
